Comp 280 Cams, ARP head studs stock internals, Gauges
Old Jan 1, 2009 | 08:34 PM
Joshs EVO's Avatar
Gauge Pod, Gauges, Stock intake manifold
I have a few things laying around the house that I would like gone.
****New parts added on bottom of list***(bottom 2 parts)
52mm Steering column gauge pod..... 25
RR trunk......200 shipped....damaged though some scratches
ACT clutch......150 Used ACT clutch for about 5k
Stock strut tower bar......45
Stock fan......45
05 RS Ecu.....150
Blacked out tails.....50 you will need a new lens on one of them....see pic
52mm gauge visors.....10 each
RS three gauges oil tempt, boost volts 110
Entire A/C parts, compressor, lines.....80
Stock Intake manifold.....120
Old Jan 1, 2009 | 08:41 PM
Joshs EVO's Avatar
more pics
Old Jan 1, 2009 | 08:43 PM
Joshs EVO's Avatar
more pics 2
Old Jan 1, 2009 | 09:40 PM
varner88's Avatar
ill take the 02 sensor pm me paypal info
Old Jan 1, 2009 | 09:49 PM
Joshs EVO's Avatar
PM'd
Old Jan 1, 2009 | 10:05 PM
Joshs EVO's Avatar
Bedtime bump
Old Jan 2, 2009 | 07:31 AM
Joshs EVO's Avatar
At work...bump
Old Jan 2, 2009 | 07:57 PM
Joshs EVO's Avatar
new pic of the Gauge lit up so you can see the color.
Also the hoods that I am selling. They help with the glare and they look pretty sweet also.
Attached Thumbnails Comp 280 Cams,  ARP head studs stock internals, Gauges-picture-001.jpg   Comp 280 Cams,  ARP head studs stock internals, Gauges-picture-008.jpg   Comp 280 Cams,  ARP head studs stock internals, Gauges-picture-009.jpg   Comp 280 Cams,  ARP head studs stock internals, Gauges-picture-010.jpg
Old Jan 2, 2009 | 07:59 PM
Joshs EVO's Avatar
Also the water temp adapter with a temp sender is now pictured above
Old Jan 3, 2009 | 06:09 PM
Joshs EVO's Avatar
Meth kit Pic added.
Old Jan 5, 2009 | 05:15 PM
Joshs EVO's Avatar
injector pic added....
Old Jan 6, 2009 | 12:40 AM
HP06MR's Avatar
pm'd
Old Jan 6, 2009 | 03:32 PM
Joshs EVO's Avatar
PM'd you back
Old Jan 17, 2009 | 09:59 PM
Joshs EVO's Avatar
Bump.
Still have the Meth kit
Old Jan 24, 2009 | 11:58 PM
Brokenevo's Avatar
do you have the bolts for the arp studs? I just need the nuts if you do. lemme knwo
