Hallman Pro Evolution RX in cabin manual boost controller RED
SOLD SOLD SOLD SOLD
I've got a brand new, in the box HALLMAN PRO RX Evolution (in cabin adjustment) manual boost controller for sale -- it's the RED anodized valve and controller combination shown in the pictures below.
Here's the description of the boost controller straight from Hallman's literature:
Hallman Pro RX Manual Boost Controller (ceramic ball)
The Hallman Pro RX Kit contains
-- the Hallman Pro valve with a ceramic ball,
-- both light AND heavy (standard) springs,
-- 3 feet of hose, mounting bracket,
-- hardware packet, and
-- complete installation instructions.
The RX kit has a ceramic ball instead of the 316 stainless ball that comes in the Hallman Pro and Hallman ES valves. The ceramic ball weighs a fraction of what the stainless steel ***** weighs. This weight difference allows the ceramic ball to act very quickly as it is constantly changing directions during operation. This helps to minimize spiking, particularly when used with applications that produce lower boost.
The RX kit also includes a light spring. The light spring allows for very fine adjustment of boost up to 4 to 5 pounds of boost over "stock". Boost can be adjusted in as little as half pound (.5 PSI) increments very consistently with this valve.
The combination of the ceramic ball and the light spring make the Hallman Pro RX kit very well suited for the turbo enthusiast that wants to add a few psi of boost over stock, and have a great amount of control over those few pounds.
While this kit comes with the light spring already installed, it also includes the heavy (standard) spring (that is found in the Hallman ES Kit and Hallman Pro Kit) for customers that would like to switch to the heavier spring and adjust to more than 5 psi of boost over stock, yet still take advantage of the quick-acting qualities of the ceramic ball. This is particularly helpful if your turbo system is only designed to allow increasing the boost a "small" amount now, but you modify your system to allow for higher boost levels in the future. Switching to the heavier spring allows the Hallman Pro RX Kit to "grow" with the rest of your turbo system!
Hallman Evolution Manual Boost Controller (adjust inside)
The Hallman EVOLUTION Kit uses the same valve as the Pro Kit, and has the same features, but ALSO is integrated into a self-contained cockpit controller cable system.
It also contains a mounting bracket, vacuum hose, a hardware kit, and specific installation instructions. The cable is approximately 69 inches in length. Available in Red anodized finish (or Black).
The self contained cable system allows you to adjust boost from inside your car! This new system makes it very easy to set initial desired boost level... there is no need to stop the car, pop the hood, adjust the valve, then drive to see what boost level it is set at (and possibly repeating this process several times). Sitting at a red light and want to turn up the boost? Its just an arm's reach away.
This unique cable system uses a sheathed cable that does not twist or bind. There is no "lateral torque". This means that you achieve consistent results when you turn your inside-the-cockpit adjustment knob. Just as precise as if you were turning a knob on the controller itself, as with the Hallman Pro or Hallman Pro RX kits.
Achieve the convenience of an electronic system (without the expense or complexity of electronics), with the reliability of a precise mechanical, manual boost control system!
Normal internet retail cost is $165 plus shipping. I'll sell this one for $125 shipped. First come, first served.
Thanks for reading.
Thanks for reading.
FS[West]: Hallman ProRX boost controller (Red)
CO_VR4
Dec 22, 2016 05:59 PM
DynoFlash
32
May 3, 2005 02:40 PM
boost, brand new, cabin, ceramic ball, controller, evolution, evolution rx, hallman, instructions, manual, mbc, opinions, pro, rx, user
