used evo x block for rebuild
IM LOOKING TO GET AT LEAST 650 SHIPPING IS 85 I NO LONGER NEED IT GOT LAID OFF
SO CANT FINISH MY DREAM BUILD
OFFERS WELCOME
THIS HERE IS A 4B11 ENGINE BLOCK.
INCLUDES: ENGINE BLOCK LOWER CRATE AND UPPER CYLINDER CHAMBER
ALL 5 MAIN CAPS AS SEEN ON THE PHOTO WITH MAIN CAP BOLTS
PLEASE KEEP IN MIND THAT THIS BLOCK REQUIRES HONING OF THE CYLINDER WALLS BEFORE INSTALLING NEW PIStONS
ALSO REMEMBER THAT THIS BLOCK CAN ALSO BE RESLEEVED FOR THOSE OF YOU LOOKING TO FIND AN AFFORDABLE ROUT TO BUILDING THE PERFECT MOTOR.
DARTON SLEEVES RUN FOR AROUND $450 TO $525 A SET
YOU WILL NEED TO VISIT A MITSU ONLINE OR AT THE STORE TO ORDER THE BOLTS FOR THE OIL PAN I WILL ALSO HAVE FOR SALE A NEW OEM OIL PUMP IF YOU ARE TRULY LOOKING TO BUILD THE MOTOR AND ARE IN NEED OF ONE I WILL SUPPLY YOU A NEW ONE FOR HALF THE COST SINCE I NO LONGER NEED IT
THANKS AGAIN FOR READING
NOTE: ANY PERSONAL OFFERS PLEASE FEEL FREE TO MESSAGE ME THANKS AGAIN
OFFERS WELCOMETHIS HERE IS A 4B11 ENGINE BLOCK.
about 47k from when i initially got it but thats not what matters on the block what matters most is the crank pistons rods n bearings you use as long as those are new a sturdy block is a good fit
