CMGS FS stage 2 meth kit with 2 CM5 injectors
SOLD!!!!!!!!
FS: CMGS FS kit for only $200 + shipping and paypal fees
-originally installed in a evox
- this kit overall was used for around 6 mos..i removed it around 6-8mos ago due to i was considering on selling the car. i forgot all about it and i was cleaning up the garage and saw this few days ago. if you sum this up, this kit will be close to $700
- the kit will come that everything that i used to install it
- additional wires
- 2 upgraded CMGS CM5 injectors
- additional clogged detector (technically bnew never been used you will see) the T with this clogged detector was used instead for the two injector setup
- pump was never used with 100% meth i was always on 50/50mix no leaks or whatsoever
- 2 qt tank with low level fluid indicator and Devil's own tank tap with filter
- CMGS controller
- meth line
- boost line
- check valve and filter
- the flow sensor however **i think is not 100%** i recommend using a new flow sensor or get a 3rd party flow sensor. it was left in the garage for a while so i tested it out. i removed flow sensor and blew through it and it wasn't making the whinning noise, i tapped it a little and it went free.
- i tested the whole system and it is flowing strong. pump fittings was covered during it was stored.
- payment will be in paypal
- no one buys this i'll make it as my intercooler sprayer
seriously
- pms only
- additional wires
- CMGS controller
- meth line
- boost line
seriously- pms only
