For Sale - Suspension / Brakes / Handling Includes pads, rotors, springs, shocks, swaybars, and other handling related components.
FS: Cusco E-Con Controller!
Old Jul 25, 2006 | 05:12 PM
bluesaint's Avatar
FS: Cusco E-Con Controller! SUPER CHEAP
I have 2 of these. Super LOW PRICE $300 SHIPPED!!
E-Con
Memorizing!
- 6 preset memories available
- Only a push of a button needed to fit any style
Rebound Force Adjustment!
5 stage adjustment for the front and rear independently. Each shock is designed specifically for the vehicle application. (one by one adjustment operation)
Stylish Operation Panel!
With the operation panel thickness being a mere 30mm, installation and location options are increased. The compact control unit can easily be hidden away and out of sight.
Dimensions: W x D x H
Operation Panel: 100mm x 30mm x 30mm
Control Unit: 125mm x 82mm x 30mm
Adjustment Motor!
The E-Con uses high quality adjustment motors to control the rebound force quickly and accurately. The motor utilizes a special rubber cover to shield itself from moisture caused from the extreme humidity and temperatures found in the engine bay. Installation is a cinch with the specially designed bracket on the Zero-2E coilovers.
*Note: Please do not adjust E-Con while driving
Lighting Adjustment!
Brightness of the operation panel can be adjusted. (also can be turned off)
Sound Adjustment!
Confirmation sounds can be turned on or off.
Cusco Strut Bars!
Will fit with Cusco strut bars.
The E-Con kit includes:
• Rebound force controller x1
• Operation panel w/ wire harness set x1
• Main power wire/adjustment motor x4
• Wire for motor – 5m x2, 4m x2
