EVO8-9 XS Engineering POWER PACK Ignition System AMP V.2
Old May 6, 2007 | 07:08 PM
evo-mr's Avatar
MSRP: $439.00
Brand new, never installed.
Missing Manual (you can call XS Engineering, they will fax it)
asking for $240.00 shipped
Installed pictures:
http://www.xs-engineering.com/galler...id=9&photoid=2
XS Engineering Power Pack Ignition Amp V2 Mitsubishi EVO VIII
XS Engineering is proud to announce the release of the new Power Pack II Ignition Amplifier System. High revving, high-compression and turbocharged engines all require a great deal of spark energy from the ignition system to run properly. The higher the boost, the more spark energy required to fire the spark plugs to complete combustion. The XS Engineering Power Pack is an ideal upgrade for anyone who wants a compact and cost-effective way to maximize the performance of their vehicle’s ignition system.
The unit installs inline with the positive side of the coil(s) and “boosts” the input voltage all the way to 20 volts! This translates into increased spark energy regardless if it’s mated to a stock or aftermarket inductive ignition system. Also, the need for and expense of multiple ignition boxes in multi-coil applications is eliminated as Power Packs are designed to work with single or multiple coils. With its state-of-the-art internal power regulation, the Power Pack’s output remains at or near 20 volts and up to 20 amps even when the input voltage dips below 12 volts making it ideal for even racing applications where no alternator is used. Another one of the Power Pack’s key advantages is its size. Measuring only 5.25” x 3” x 1.5”, the compact Power Packs are a breeze to install even in the tightly packed engine bays of today’s cars. Furthermore, all Power Packs are fully epoxy encapsulated to survive the toughest racing environments.
Old May 6, 2007 | 11:25 PM
evo-mr's Avatar
PM replied
Old May 7, 2007 | 08:52 AM
evo-mr's Avatar
bump
Old May 7, 2007 | 06:59 PM
evo-mr's Avatar
bump again!
Old May 9, 2007 | 03:43 PM
evo-mr's Avatar
bump,... all pm replied!
Old Jun 1, 2007 | 09:39 AM
evo-mr's Avatar
bump....!
Old Jun 3, 2007 | 09:51 AM
evo-mr's Avatar
replied
Old Jul 11, 2007 | 06:35 PM
evo-mr's Avatar
bump
