FS: Battery relocation kit
Old May 13, 2007 | 09:53 AM
KY's Avatar
KY
This is a kit I pieced together for a project I was going to do, but I ended up selling the UICP that I had and went with the Greddy so now I don't have a need for this anymore.
It comes with:
20' 2 gauge power wire
20' 2 gauge ground wire(I know it is a lot, but this is how the wires came when I bought them)
2- 2 guage in-line fuse holders with 100 amp fuses
2- Brackets for battery tie downs in trunk
Terminals for 2 gauge wire(not pictured)
It is a pretty easy install and I can post pics soon of a car I already did with this same setup. Basically run the power from the oem terminal to the back with a fuse in line up front and one in the back closer to the battery(safety reasons) and run a ground to an appropriate point in the trunk. Place the brackets on where you want them in the trunk, mark where the holes need to be drilled, drill and then put the bolt through and tighten down with nut on the other side. Then hook the OEM battery tie down through the holes in the brackets and you are pretty much done.
I am asking $140 shipped.
Old May 13, 2007 | 11:16 AM
daisaw1219's Avatar
wat about venting the battery
Old May 13, 2007 | 11:24 AM
KY's Avatar
KY
Oh, I didn't think you had to do that with an Optima. Sorry, this is what I bought this kit for.
Old May 13, 2007 | 11:55 AM
DrivenToThrill's Avatar
bump good guy I'd buy it but I spent my money on othe things
Old May 13, 2007 | 03:58 PM
Cj98's Avatar
can I get better pics of the brakets and the terminals
Old Jun 14, 2007 | 08:12 PM
KY's Avatar
KY
Bump
