Pre-made CEL mechanical fix
Old Nov 10, 2007 | 09:14 AM
damstr's Avatar
Bought 2 packs of these anti fouler plugs just in case I messed the first set up, but I didn't so I have an extra mechanical CEL fix for those of us running test pipes or hi flow cats.
Here are some pictures...
This same fix has been working for me for over 500 miles and no CEL with my test pipe. It is pre-made with the drilling already done, so all you have to do is unscrew your 02 sensor, screw this into your test pipe/hi flow cat, and then scew the 02 sensor into the anti-fouler. After that just take the positive off your car to reset itself and the CEL will be off from that point on. If you do not reset the car, the light will continue to stay on.
Basically it just pulls the 02 Sensor out of the pipe to read less exhaust fumes making the car think you have a cat on your car.
$12+ Shipping.
Old Nov 10, 2007 | 03:29 PM
damstr's Avatar
Should this be in a different section? This one made the most sense to me. :/
Old Nov 10, 2007 | 09:44 PM
EVO8emUp's Avatar
FWIW, you don't need to stack them if you drill the hole w/ a 17/32" drill bit.
Old Nov 10, 2007 | 09:46 PM
chaotichoax's Avatar
I pm'ed you
