FS: ECU Patch Cable / Weapon R Engine Dampener / Perrin Catch Can / Stock Clutch+Fly
Old Oct 23, 2009 | 03:43 PM
poordude's Avatar
Engine Dampener ECU Patch Cable Stock Clutch OEM Parts 4 o2/turbo/hotside, o2 sensor
NEW Stainless Steel Braided Clutch Line $60 Paid $86 shipped @ Link - Install Guide Here @ Link
This stainless steel braided line replaces the rubber factory hose between the clutch master cylinder and the hard line to the clutch release cylinder. By replacing the pliable rubber section with this braided line, clutch actuation is more direct and the engagement point is more consistent.
Bosch Oxygen Sensor - P/N: 3737
$70 shipped brand new. Save $20 bucks!
Bosch LSU4.2 5-wire, wide-band O2 sensor. Replacement sensor for LM-1, LM-2, LC-1, and LC-1ST.
My receipt
Delivery: FedEx Ground
Subtotal: $ 79.99
Shipping cost: $ 10.27
Total: $ 90.26
Odyssey Mini Batter PC680MJ with Metal Jacket 15 Pounds! High cranking power! Still have warranty. Shave off extra 30 pounds in front end and extra 15pounds relocating to trunk $100 Paid $150 @ link
New Battery Tender $30
150watt Power inverter, nice n small no mess, personally used to run a ps2 slim and charge my laptop $25
Vibrant 2 Boilt 3" Exhaust Gasket $10 NEW
OEM Parts for installing or replacing your hotside, o2 housing, turbo. Includes gaskets, nuts, bolts, washers, etc. $100 alltogether, paid
Parts include
Gaskets
Oil drain line gasket (oil pan): MN156738
Gasket, manifold to turbo MR404547
Turbo drain tube to oil pan build 09/03 and up 1226A002
Turbine housing-O2 housing gasket: MR299686
Compressor outlet gasket: MR281085
Nuts and bolts
Bolt turbo to manifold MN119783 X2
Exhaust manifold-turbine housing stud: MN119784 x2
Turbine housing-O2 housing stud: MR224441 x2
Turbine housing-O2 housing bolt: MD062961 x3
Turbine housing-02 housing nut: MD050073 x2
Oil feed line crush washer (turbo): MF660064 x2
Screenshot of price at a oem part store
Paid $136 shipped, Selling for $100
The Ultimate Racing Fuel Pressure Gauge Adapter will allow you to bolt a fuel pressure gauge onto your stock fuel rail without any modifications or welding. $80, Paid $110 @ here
Greddy Oil Cap Chrone / Blue Shipped from Japan Took 3 Months to Arrive NEW $60, SOLD TO ROCKMANX THANKS!
New Perrin Catch Can Blue $100 - SOLD TO ROYB THANKS!
Stock o2 Housing, great for porting for extra airflow without worries of cracking compared to cheap ebay o2 housing $50 Great for hotside upgrade, port to match
[B]New Weapon R EVO Engine Torque Damper SOLD TO ROYB THANKS!
Link to installation guide - Click Here
New ECU Patch Cable $100 great for those who does not want to splice their stock ECU wires, using this plug and play harness, you can just splice the wires you need for your electronics on the harness, eliminating any signs of modifications when going back to stock or warranty work. Paid $155 shipped @ link
Stock 03 clutch and flywheel, used 1k miles, clutch works perfect, but i got in a group buy for an ACT clutch + fidenza flywheel and swapped it. As far as the clutch usage, basically I babied the car and broke in the car for first 1k miles. Had DEVOtuning remove and install my new clutch. There is no slipping, tons of life on it, never abused, never launched my car, light driving with it. Not sure how to take good pics to show that, if you have any advice on how to do so, I'll take the pics with your instructions $300 for the clutch+flywheel
Old Oct 24, 2009 | 02:56 PM
poordude's Avatar
sure
Old Oct 25, 2009 | 07:27 AM
poordude's Avatar
Odyssey Mini Batter PC680MJ with Metal Jacket 15 Pounds! Shave off extra 30 pounds in front end and extra 15pounds relocating to trunk $100
Old Oct 27, 2009 | 06:47 PM
poordude's Avatar
bumpz
Old Oct 28, 2009 | 03:34 PM
poordude's Avatar
bumpy added new stuff
Old Nov 1, 2009 | 11:56 AM
poordude's Avatar
bumps
