FS: Meth injection pump replacement EPDM (methanol safe) seals
Shurflo style methanol injection pump seal for Labonte, aquamist, AEM style meth injection pumps. If your flow and pressure has dropped or your are running lean all of a sudden, you probably need this new seal replaced. You can also use this seal to make Northern Tool off the shelf shurflo pumps methanol injection compatible. Using the standard seals, they will blow out within a few days.
$30 shipped
EDIT- I can throw in a replacement pump head also for the first one ask for it.
