fresh built 2.2 liter engine
Sorry to let u know, my tuner built his 2.4L with i-beam rod and wisco hd piston and everything, came out to be $3346 total. So u might wondering y people havent answer u. Just wanted to let u know buddy!!!!!
He has probably built more 4g's then you have posts.
Nice choice of parts Jerry. Building one similar with the Carrillo H beams I purchased from you.
Can I ask why you would put in an Eagle crank and take out the OEM? I Love the build and am interested.. but the eagle crank is a down grade IMO. PM Sent.
its not a 9 block, but you can use it in a 9 with correct mivec oil feed line/adapter
evo 8 has oil pressur sender mounted to block. evo 9 has oil sender on oil filter bracket. it uses the hole on block to feed the mivec. only difference in two blocks are what thread that hole is tapped for.
Bump for a good deal, and obvious quality in work. Eagle cranks do not have a bad name anymore, one bad batch of eagle dsm cranks and they get a bad name, but people still love to run kelford cams that snap in half and screw your whole engine build? Heh.
