[FS] 2.0LR Half Filled Race Motor and Built Curt Brown Head
I decided to go full fill and run straight methanol so this motor will not work any more. Because of that I have my recently assembled 2.0 Long Rod motor. I have all receipts for the shortblock and all build specs. Specs are as follows
4g63 block bored to 85.5, half filled for stability
Decked - Line Honed - Squirters Deleted - Clearanced for Rods
RNR Aluminum Rods
Manley Pistons with upgraded tool steel pins
ACL Bearings
ARP Mains
Micro Polished Oil Pump Gears
Gates Water Pump
Head is an evo 8 curt brown head, full fort and polish
O-ringed
Stainless inserts placed in head for more consistant torque specs
OEM valves
Supertech dual springs with titanium retainers
Motor was built by one of the best supra engine builders in the world (Donald Summerton at Accellerated Performance) and no expense was spared (I have 3150 in machinework and assembly alone). The ONLY reason I am selling it because I am going to a much more aggressive setup.
I am asking 5000obo for the shortblock and 2000 for the head. Or 7500 for the longblock that will include a set of arp 626 headstuds, gates timing belt, tomei 290 cams, adjustable cam gears, modded factory oil pan, fully assembled minues a valve cover.
RNR Aluminum Rods
ACL Bearings
ARP Mains
Gates Water Pump
O-ringed
OEM valves
FS posts on EVOM MUST INCLUDE:
PICTURE OF THE ITEM WITH A SIGN CONTAINING THE DATE AND YOUR EVOM USERNAME.
Price
Accurate description of item and its current condition.
Location of seller & Willingness to ship.
If applicable VIN number - Transmissions, Shortblocks, body parts which have VIN numbers on them. A picture of your username/date next to the visible VIN number is required. VIN should also be in the FS post in plain text.
Price
evo8vz
Jan 5, 2017 07:17 PM
FS[Northeast]: Curt Brown Fully Built Head
12WWGSR91
54
Jan 25, 2015 11:15 AM
BigT
39
Jan 17, 2012 10:36 AM
