FS: Gt35r Turbo only
SOLD!!!!!!!!!!!!!!
I have a Gt35r with about 10k miles on it. Highest boost It has seen is 28psi which netted me 540whp. It does have the true garrett .82 a/r exhaust side which you can tell by the 4 bolt pattern. Its has a 02 housing welded to it and can be used and any stock placement downpipe. It has the t04s 4in compressor housing cover with anti surge ports. I want to get a bigger turbo and that is the only reason for me wanting to get rid of it. I did have the compressor housing polished the the hotside jetcoated. I have about $1500 in the turbo. I would take $950 shipped for it. http://i163.photobucket.com/albums/t...r/P5090135.jpg http://i163.photobucket.com/albums/t...r/P5090134.jpg http://i163.photobucket.com/albums/t...r/P5090133.jpg http://i163.photobucket.com/albums/t...r/P5090132.jpg --Josh |
Bump!!!
ANY Interest?? Pm me with offers!
what manifold were you using with this turbo? Some manifolds sit the turbo lower than others, and i want to make sure the downpipe will line up. thanks
I was using an rnr manifold.
--Josh |
I shined up the compressor housing today!! Check it out.
--Josh |
bump
BUMp
bump $950 shipped
any shaft play, I know how many miles it has but how old is it, when did you buy it and from where? Can the O2 housing welds be removed?
Originally Posted by EVO8TOR
(Post 4330660)
(Post 4330660)
I have had it since april of 06. So about 1 year and 1 month is has been running. I bought it from rnr. And yea the welds can be cut off and you could put anything you needed there. Or even get the 4 bolt flange to weld to a downpipe to bolt right up. |
Originally Posted by SwiftEVO
(Post 4330977)
Minimum shaft play. Just a normal amount.
bump for a sweet deal
(Post 4331943)
Vey interested....how low will you go shipped...will you take $850.00 shipped I can send the money today.
Thanks for the bump --Josh |
