Im selling a ATP Stealth Bolt-on GT3582R Ball Bearing Garrett Turbo 03-07 Mitsubishi Evo VII/VIII/IX. It will include the turbo, steel braided lines and fittings for coolant connections (no oil lines or fittings), flange with clamp for downpipe, one silicone conector. 100% bolt-on design. No welding, cutting, or fabrication. It only needs a 3" vband downpipe, a external wastegate 2 bolt (i also have a tial wastegate for sale, email or pm me if you want the wastegate) and the wastegate dump tube. Direct bolt-on installation to factory turbocharger location. This turbo allows you to use the oem exhaust manifold.
Turbo specs: Turbo Gt3582R Minor diameter Mayor diameter Trim A/R
Compressor 61.40mm 82.00mm 56 0.70
Turbine 62.32mm 68.00mm 84 N/A
I rebuild this turbo 1 year ago on 1/14/2015, i purchased the garrett gt3582r turbo cartridge, it cost me $815 (i attached pic of the old cartridge) so this turbo basically is in very good condition. Great bolt on ball bearing turbo with quick spool to make 400-460 hp on pump gas. Im asking $760. Pm me or sent a email to: Jeriel.Sanchez@upr.edu
Ki part number: ATP-VEVO-006.
