Old Jun 17, 2016 | 12:14 AM
  #1786
CrAnSwIcK's Avatar
Originally Posted by truthdweller
I don't need to do the same to the high pressure side, or are they connected?
they're connected by the compressor...I didn't think there couldn't be a check valve or the higher pressure would just keep it closed forever...I would empty the low pressure, and then see if I could easily open the servicing valve on the high pressure side with a screwdriver or something...
Old Jun 18, 2016 | 02:59 PM
  #1787
truthdweller's Avatar
Veteran: Navy
AC Compressor, lower low pressure hose, and mounting bracket is out:
Down Pipe and WG Housing is off:
...and one broken bolt stuck in the turbine housing:
Old Jun 20, 2016 | 06:41 AM
  #1788
bakuro117's Avatar
You might want to put that AC bracket back on. I believe taking it off exposes your timing belt IIRC. You dont wanna risk getting anything inside of there.
Old Jun 20, 2016 | 11:50 AM
  #1789
Veteran: Navy
Through the bolt holes? For, I don't see any other way...
Old Jun 20, 2016 | 12:03 PM
  #1790
Veteran: Navy
I also got that bolt drilled out (easy-out didn't work) and tapped with it's original size, M8 - 1.25...
Old Jun 20, 2016 | 12:16 PM
  #1791
Veteran: Navy
aaaaand, a 60" serp belt worked purrrrfectly...
Old Jun 20, 2016 | 02:52 PM
  #1792
CrAnSwIcK's Avatar
Yeah I used a 59" and I could not get it on the correct side of the idler without maxing out the tensioner....60 it is...easy to remember too
Old Jun 20, 2016 | 06:11 PM
  #1793
Veteran: Navy
When drilling out that bolt in the turbine housing, I (***)umed that the hole went through and through the wall, into the housing, but found out after the fact that the others didn't. Is this going to create an exhaust leak around the bolt threads???
Old Jun 20, 2016 | 06:51 PM
  #1794
CrAnSwIcK's Avatar
Shouldn't, the gasket should seal around the bolt
Old Jun 20, 2016 | 07:04 PM
  #1795
Veteran: Navy
Gasket, what gasket? I've never run with a gasket, nor ever saw one! The V-band flanges have an option to use a gasket, but only if your pushing upwards of (50) psi, etc.
The guy at LTP Tune, where I purchased the turbo, recommends Permatex high temp copper sealant around the threads only.
Old Jun 20, 2016 | 07:16 PM
  #1796
Veteran: Navy
Off topic...are you following Blue Origin's progress Garrett?
Old Jun 21, 2016 | 07:07 AM
  #1797
bakuro117's Avatar
Hmm.. maybe it was the alternator bracket i was thinking of. I'll double check when I get home.
And I thing Garrett is talking about the gasket between the turbo and the down pipe.
Old Jun 21, 2016 | 12:19 PM
  #1798
Veteran: Navy
I figured that as well when I looked up there, but the "bracket" for the alternator looks to be casted onto the engine block. Anyhow, I don't see any issues.
And I thinK Garrett is talking about the gasket between the turbo and the down pipe.
Yep, that's what I'm referring to as well, and I don't use a gasket, just metal to metal and haven't had any issues. Iirc, way back at the beginning of my build, I believe we discussed the same and concluded that either way was acceptable. Obviously, everything is good to go since. I'll coat the threads of the one bolt in question with some of that Permatex when I button this thing up.
Right now, I'm looking for the best place to purchase Ultra Tight Radius Mandrel Bend 90 Degree 304 Stainless Steel 0.84D Exhaust pieces to finish the down pipe. So far, I've only found them on Ebay.
Old Jun 21, 2016 | 03:20 PM
  #1799
CrAnSwIcK's Avatar
some things are ok to buy on eBay, just be aware of wall thickness when buying pipe. Also I haven't been keeping track of privatized space flight lately...though I did watch the falcon 9 test...pretty exciting stuff, makes me want to get out of conventional aircraft maintenance and get into building space craft... lol
Old Jun 21, 2016 | 07:09 PM
  #1800
Veteran: Navy
What minimum wall thickness are we looking at for the down pipe?
