Evo How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Evo 9 cam install . Very simple question
Old Mar 15, 2017 | 12:50 PM
Welcome2GoodBur's Avatar
I already broke the 12mm front the exhaust cam housing. Trying to bust the 17mm off the sprocket. Want to make sure I'm not making things harder for myself. Do I leave it in gear or out of gear when breaking the bolt? Also, does the timing tool go in before or after breaking the 17? Appreciate any feedback
Old Mar 15, 2017 | 01:46 PM
Pal215's Avatar
Here is the full write up.
http://www.evomoto.com/tech_articles..._article_id=18
To answer your question, the car in gear doesn't matter too much because there will be some movement in the motor regardless. You will want to put a wrench around the cam shaft in the "hexed" location and break the 17mm bolt loose with a breaker bar. The timing tool will go in after you have zip tied the timing belt to the cam gears.
Picture taken from evomoto:
Old Mar 15, 2017 | 02:22 PM
Yeah I get that I zip tied the belt already. I've got someone holding the one side and me yanking the 17 on the cam. We just appear to be working against each other. Whoever is the stronger one moves the other at some point. Should the cam be freely rotatin like that, or will putting it in gear help?
Old Mar 15, 2017 | 04:04 PM
Update:::: got em out. The exhaust was the only issue. The intake was so easy we almost smacked into the hood
Old Mar 15, 2017 | 04:12 PM
Pal215's Avatar
haha, was this on an 8 or a 9? Yeah they can be very stubborn at times. Putting it in gear wouldn't take the slack out of the valve train enough to lock up the cams even with the timing belt installed.
I can usually break it loose myself, but having a breaker bar and an extra long wrench helps.
Glad you got it out
Welcome2GoodBur
Feb 13, 2017 12:04 PM
May 26, 2009 05:30 AM
eccgangster
Apr 5, 2006 11:23 PM
