No secondary rev limit on the MR
Old Oct 24, 2004 | 01:05 PM
EFIxMR's Avatar
After breaking in my car I tried reving it past 5 k while stationary.... The conculsion is that there is no secondary rev limit as described by magazines. At least in my car there isn't.
Old Oct 24, 2004 | 01:09 PM
05-EVO-GSR's Avatar
Try depressing the clutch pedal to the floor and then floor the gas pedal. The engine will bounce off the 5k mark. The 5k rev limiter is there, it even states it in the owners manual for reference.
ezhangin's Avatar
yeah I was wondering about that, thanks for clearing that up
Old Oct 24, 2004 | 01:14 PM
YellowFever's Avatar
i thought the rev limit thing was for 1st gear only
Old Oct 24, 2004 | 02:07 PM
MisterSpoot's Avatar
No, when stationary or below certain speeds (probably < 5 mph). If you couldn't run the car through first, a lot of folks would scream bloody murder.
Old Oct 24, 2004 | 02:14 PM
eclipsegs2k1's Avatar
It is only when the car is stationary and the clutch pedal is fully depressed... that is the ONLY time
Old Oct 24, 2004 | 02:35 PM
Evolboost's Avatar
Cool. Thanks for the info. Is this rev limiter only on the MR? Would my '03 Evo have it?
Old Oct 24, 2004 | 11:18 PM
no
Old Oct 25, 2004 | 03:00 AM
EFIxMR's Avatar
i'lll try it again tomorrow. but i did have it in 1st gear, no rev limit...
Old Oct 25, 2004 | 03:02 AM
Jakeg97's Avatar
so what did you find?
Old Oct 25, 2004 | 09:46 PM
EFIxMR's Avatar
i found that you can initially rev the engine beyond the 5k limit, but if you stand on the throttle the limiter kicks in. don't know if i would want to use it as launch control though, as it doesn't sound smooth. i was in a rush and could really tell if it was building boost.
Old Oct 26, 2004 | 09:32 AM
51's Avatar
51
Hey EFIxMR, I think there might be an easy way to remove the 5k launch limiter on MR's but I need you to try this on your car & see if it works. Try unplugging the clutch switch on your car & see if it works. It should be easy to find, it should be right behind the clutch pedal arm. Let us know what you find. By the way if you disconnect the switch you can start your car without pressing the clutch.
Old Oct 26, 2004 | 09:40 AM
Tureno-AE86's Avatar
does this apply to the 05 gsr?
Old Oct 26, 2004 | 01:41 PM
EFIxMR's Avatar
alrite i'll try it and let you know what i find out.
Old Nov 1, 2004 | 09:31 AM
51's Avatar
51
Have you tried it yet?
