Cosworth Full Head Build Price!!!
$4,500.00 For EVO 9 AND $4,450.00 FOR EVO 8 (Should be over 5k)
Here is what it that price includes!....
1. Shipping for all parts!
2. Cosworth Cams (of your choice for 8 264 or 272)!
3. Cosworth Head gasket (85 or 86mm)!
4. Cosworth Big Valved head!
EVERYTHING IS IN STOCK READY TO SHIP!!!(EVO9 cams on there way)!!!
High Performance Head Gasket, a must for high boost engines, Cosworth high performance head gaskets use multi-layers of stainless steel for increased strenght. The outer layers are embossed with a flouroelastomer rubber material designed to meet the demands of harsh sealing environments and load conditions.
Bore=85mm, T=1.0mm each.
Cosworth camshafts are ground on NEW chill cast cores to the highest standards. Each cam profile is carefully designed to maximize performance across the entire power band, producing strong power gains throughout. Prices includes two camshaft.
Duration 272
Lift 11mm.
NOW TIME FOR THE BAD BOY:
Cosworth CNC ported cylinder heads feature dyno tested and flow bench proven ports, engineered for maximum usable power. Each new cylinder head is ported on a 5 axis machine to ensure consistency and perfect port shape every time. Additionally, larger intake (+1mm) and exhaust valves (+1mm) are utilized to help increase flow. Cosworth CNC ported Big Valve cylinder heads come complete with a performance valve job, hi rev (max 10,500rpm) valve springs with titanium retainers and are ready to install. Perfect for high performance applications
Includes
CNC Ported - New Castings
Hand blended finish work
Intake ?26% (max) increased flow
Exhaust ? 18% (max) increased flow
4-angle Inlet Valve job
3-angle & radius Exhaust Valve job
Valves are lapped
Back-Cut Inlet Valves
Heads are Ultra Sonic cleaned prior to assembly
Heads are Serialized and sport a machined Cosworth logo
+1mm Stainless Steel Intake Valves (1800 degrees max.)
+1mm Inconel Exhaust Valves (2400 degrees max.)
Performance Valve Springs
Titanium Retainers
Hardened Steel Spring Platforms
OK Also if you need timing belts(HKS) head studs(cosworth) and intake manifold gasket(AP) add-$390 (shipped
EVO9 CAMS LINK; https://www.evolutionm.net/forums/sh...d.php?t=229837
Duration 272
Lift 11mm.
Includes
Valves are lapped
Titanium Retainers
