Vendor Service / Parts / Tuning Review Post your service, part & tuning reviews here. Please note all new threads are moderated.
Buschur Racing twin Walbro review w/ DLL dyno and datalogs @ 30psi 93 octane
Old Apr 12, 2008 | 10:13 AM
Mellon Racing's Avatar
big thanks to bushcur for making such a good and inexpensive solution for 500+awhp cars. Shipping was fast and Nick was pleasant to work with as well.
let me preface this review with some data.
I've been on the stock ecu/mas running 30psi on a BR HTA 35R with 93 octane and PTE 880cc injectors with a single walbro fuel pump plus a kenne bell boost a pump cranked all the way up. I kept adding fuel at high rpm in the ROM and eventually I got the AFR where I wanted it but the IDC was 110% peak.
I pulled the single pump and kenne bell boost a pump, installed PTE 1000cc injectors and the Buschur Racing twin walbro kit.
The kit comes with a hobbs pressure switch so that when you're off boost it only runs one of the pumps. Once you get ~ 3psi+ the second pump kicks in.
The twin pump kit uses most of the factory fuel pump assembly so the install/removal is similar but a section of factory hose is replaced with twin hoses. It's a little tricky to get it all to line up but not too bad. You'll run a wire from the battery/hobbs switch back to the pump.
Tuning was a little tricky, there's way too much fuel at part throttle but I was able to dial it in eventually and now you can't tell it has a massive fuel supply at all, feels like stock driveability again
I did a few 3rd gear pulls and DLL is showing ~500awhp currently which is good for this warmer weather we've been having.
log from that pull: looks like I'm hitting about 86% IDC now, much better.
Code:
RPM		KnockSum		LoadMUT2Byte		InjDutyCycle
2531.25		0		70.3125		5.94
2531.25		0		86.5625		9.18
2562.5		0		87.8125		7.653333333
2593.75		0		88.75		7.746666667
2625		0		89.0625		8.4
2656.25		0		90.625		8.5
2687.5		0		92.1875		8.6
2750		0		94.0625		9.386666667
2781.25		0		96.5625		9.493333333
2843.75		0		98.75		10.31333333
2843.75		0		101.25		10.31333333
2906.25		0		102.5		11.16
2937.5		0		104.6875		11.28
3000		0		108.125		11.52
3031.25		1		110		11.64
3093.75		1		111.5625		12.54
3125		2		114.6875		12.66666667
3187.5		2		116.25		12.92
3250		1		118.125		13.17333333
3312.5		1		119.0625		13.42666667
3375		1		122.5		13.68
3437.5		1		126.5625		14.66666667
3500		1		129.6875		14.93333333
3562.5		0		131.875		15.96
3593.75		0		135.3125		16.1
3687.5		0		142.8125		16.52
3718.75		0		147.5		17.45333333
3812.5		0		155.3125		18.70666667
3875		0		168.75		19.84
3937.5		0		175.3125		21.84
4000		0		183.125		22.18666667
4125		0		191.875		25.52
4187.5		0		213.125		28.58666667
4281.25		0		228.75		31.96666667
4375		0		262.1875		38.26666667
4531.25		0		291.875		46.4
4687.5		0		277.5		49
4781.25		0		289.6875		51
4937.5		1		303.4375		54.77333333
5093.75		1		307.1875		58.68
5281.25		0		313.4375		60.84
5437.5		0		321.25		62.64
5593.75		0		325		65.63333333
5781.25		0		330.3125		67.83333333
5906.25		0		330.9375		69.3
6093.75		0		339.0625		71.5
6250		0		340		74.66666667
6375		0		345.625		77.52
6593.75		0		344.375		78.77333333
6718.75		0		343.4375		80.26666667
6875		1		340.9375		80.66666667
7093.75		1		344.375		81.72
7218.75		0		341.875		83.16
7343.75		0		338.4375		83.03333333
7531.25		0		337.5		83.54666667
7625		0		335		84.58666667
7750		0		332.8125		85.97333333
7875		0		327.8125		85.68
7968.75		0		327.8125		86.7
FYI current mods are:
BR HTA 35R @ 30psi on 93 octane
HKS 280 cams
BR twin walbro fuel pumps
BR 3" tbe, test pipe, bullet muffler
BR 3" intake pipe + Mas adapter
BR UICP
BR Mini Battery
BR Race FMIC
ARP head studs
PPI ported stock intake manifold
PPI 65MM throttle body
Exedy Twin Disc HD clutch
My tuning www.mellontuning.com
The next round of mods will be:
Buschur Racing built 2.0l
Buschur Racing built head
Buschur Racing BF 272 cams w/springs and retainers.
It'll be really interesting to see how much air I'll be able to flow at the same boost after the shorty/head/cam upgrades.
Old Apr 12, 2008 | 10:31 AM
evovin's Avatar
Nice!
Same boost?
Old Apr 12, 2008 | 10:41 AM
yep, I have seen as high at 535awhp but that was when it was 20* outside, it's 75 or so now.
Old Apr 12, 2008 | 04:03 PM
FLOW1's Avatar
Nice Chris. Much better improvement then last time :P
Old Apr 12, 2008 | 04:18 PM
Sharkbite2000's Avatar
Great power #'s for the pump
Old Apr 12, 2008 | 05:51 PM
High_PSI's Avatar
Outstanding.
Old Apr 12, 2008 | 06:14 PM
Jspec EVO VIII's Avatar
Nice numbers. Wondering does Buschur offer a 4" intake instead of a 3"?
Old Apr 12, 2008 | 06:28 PM
I'm sure they'd make one but either way you're limited by the stock mas inlet size so I doubt it would help.
Old Apr 12, 2008 | 06:49 PM
evovin's Avatar
How about using maf translator?
Old Apr 12, 2008 | 09:01 PM
I'm not a fan of those things...tried a half dozen of them on my Stealth and the tune was always drifting off when the temperature changed...not acceptable.
Old Apr 13, 2008 | 03:50 AM
dxbevo9's Avatar
what kinda tricks did you do to tackle the issue of exess fuel at partial throttle???
keep us updated...i love how solid and consistant your numbers are.
thanks.
Old Apr 13, 2008 | 11:01 AM
the tricky part is identifying the bad spots, then it's just a matter of leaning out the fuel map where necessary.
Old Apr 13, 2008 | 11:07 AM
I finished the fuel tweaking this morning, slightly leaner across the board:
Old Apr 14, 2008 | 01:23 PM
SLVRNBLK's Avatar
Veteran: ArmyFCOTM Winner
Awesome data! Great to see those results on the stock MAF. I've been following your progress from the begining. My build is mirrored to yours.
Old Apr 15, 2008 | 06:34 AM
Jrod@Buschur's Avatar
Thank you for the post Chris we appreciate it!
Glad you like the new setup.
