Evo X L.E.D. product lineup.
Former Vendor
Updated 1-8-09. 2008 and up Lancer, Ralliart, Evo.
I am a vehicle specific LED seller and customizer. I know what works, what fits, and looks the best. I only offer the best stuff out there. I have spent countless hours reasearching, R-D'ing, and spent alot of money seeing what works and what doesnt. But nothing is perfect so I will go above and beyond to fix any problems or concerns. If you want 3 dollar LED's go away. You wont find them here. If you dont like my brightness I will buy them back from you.
Thanks for looking.
Mr. Energy Leds.
Curt Sonnenberg
When you ordering please list these items with your payment. Please confirm your paypal home address also.
My paypal is MrLed@comcast.net All prices include shipping.
Copy below info in the message section in your paypal.
1. The site your buying from, and your screen name.
2. What style lighting, and color.
3. What model car the order is for.
__________________________________________________ __________________________________________________ ____________________________________
Click pictures for larger images.
Interior lighting. Install Instructions included. Prices include shipping..
2 Or 4 pieces of Bright LED front map/dome lights.
Colors, Brightnesess can be mixed. 2 sections for the map lights. Plug, stick, and enjoy. Install instructions included. Red, White, or Blue.
2 pieces, 60 leds 50.00
Or
F-ing bright. 96 LED's 66.00
Or
Like looking at the sun. 120 leds 90.00
Center/Rear dome light, 1,2, or 4 pieces.
Here is the center dome light for guys with no sunroof. .
Availible red, white or blue. Perfect color match to the F'ing bright front LED dome lights. Plug, stick, and enjoy. Install instructions included.
Normal brightness. 30 LED'S 25.00
Or
Bright. 48 LED's 33.00
Or
F-ing bright. 60 LED's. 50.00
Or
Way too F-ing bright. 96 LED's 66.00
Or
Foot well lighting. .
These can be wired to come on when the parking lights are turned on. Or you can add your own switch to turn them on when you want. See Hook up for LED's below for easy connection to power them on.
Red, White or Blue. 1 Aluminum LED module per side. Very small and bright.
Plug-in style comes with install directions, zip ties for mounting, and wire. Red, white or blue. These are cheaper, safer, easier to install, smaller, and energy efficent unlike neon lighting.
55.00 for 2 LED's.
Or
35.00 for just the 2 LED's you wire them in.
Interior light LED's.
Please read carefully as I try to add as many options as possible for you.
These LED's are sold with enough wire to hook up under the cup holder with my crimp on connector (Sold separately.) kit that taps into the stock wiring harness. No cutting of any wires. This hookup powers the LED's when the parking/headlights are turned on. You can also opt for me to add more wire so you can hook them up how you want, as well as a small toggle switch that can also be used in conjunction to turn them off when hooked to the parking/headlights. Picture install directions included. You will need to drill a small hole to install the LED's
Colors availible, Red, White, Blue, Green, Yellow, U.V./Purple.
Hookup for LED's under the cupholder that power on with parking/headlights.
This is for footwell lights, cupholder, armrest, cup holder, and any other lights you want. Only one is needed. Hookup as many LED's as you want to this.
15.00
Small toogle switch to power on the LED's as you wish.
Comes with 10 feet of wire already soldered to the switch, and a wire end to plug into the fuse box..
25.00
1 Armrest compart LED.
15.00
1 Shifter console LED.
15.00
Cup Holder LED's. 2 Pieces.
25.00
Thanks for looking.
Mr. Energy Leds.
Curt Sonnenberg
Or
Or
Or
Or
Or
Or
55.00 for 2 LED's.
Or
15.00
25.00
15.00
15.00
25.00
Former Vendor
Trunk light, L.E.D. bulb replacement.
Brightness is between stock and super bright below. Red, White, or Blue
18.00
1 Super bright Trunk light L.E.D..
Red White or Blue. 02 thru 08 Lancer and Evo. 30.00 Shipped. Plug, stick, and enjoy. Install instructions included. Nothing is brighter.
After market gauge lights.
Any oil pressure, boost, water temp, oil temp, a/f gauge that uses a 194 L.E.D.
Wont overheat, extremly bright. Red, White, Blue.
194 style, Wont overheat, extremly bright. 4 smt L.E.D's per bulb.
14.00 a peice. Plug, and enjoy. Install instructions included.
Exterior lighting. Shipping included.
License plate lights.
Stock.
White color with a slight hint of blue. Not a obnoxious blue that may cause problems with the cops. These are replacements for your bulbs. The whole plate is illuminated unlike what others sell. Plug, stick, and enjoy. Install instructions included. No one else sells these bright L.E.D's. I custom make them for the Lancer-Evo.
What cheap leds look like. If you want these I dont sell them.
2 Pieces, L.E.D plugin replacements.
2, 1 watt L.E.D's. 21.00
2 Pieces, Brighter L.E.D. 5000k white L.E.D's.
Absolutly zero shadows on the plate. Custom Plug-in L.E.D. panels that are exclusive to me. No one sells a plug-in light this bright for these car's but me.
35.00
2 Pieces, Brighter L.E.D. 6000k Blueish Hue L.E.D's.
35.00
2 Pieces, F-ing Bright L.E.D. 60, 5500k white L.E.D's.
52.00
Plug-in style L.E.D's. Tails and headlights.
Taillights.
These will save you gas milage at night, brighter than stock, brightest and best on the market, illuminate faster than stock, plus these are true colors not orangeish like stock. Want cheaper stuff go elsewhere. I wont sell them.
Trunk Side 7440 Reverse L.E.D. Not availible for the MR.
2 peices. 50.00
L.E.D. on left, Stock on right.
2 peices. Hi-Po. Brightest Led reverse lights that you can buy.
75.00
Trunk Side 194 Parking L.E.D. Light.
2 peices. 33.00
Body side 7443 Park and Stop L.E.D. Light.
2 peices. 50.00
Or
2 peices Brightest Led turns made, 5 watt power usage perside.
75.00
Body side Amber 7440 Turn Signal L.E.D.
2 peices. 50.00
Or
75.00
Body side 194 Park L.E.D. Light.
2 peices. 20.00
Load resistors.
2 of my load resistors will cover front and back led fast blink problems. You only need 2 with the ones I use, not 4.
Self sticking, 5 minute connection times. So easy I can do it blind.
2 Load resistors, 27.00 Plug, stick, and enjoy. Install instructions included.
18.00
Stock.
35.00
35.00
52.00
Taillights.
2 peices. 50.00
75.00
2 peices. 33.00
2 peices. 50.00
Or
75.00
2 peices. 50.00
Or
75.00
2 peices. 20.00
Load resistors.
Former Vendor
H.I.D's For the Evo X.
Plug and Play. 1 year warrenty.
D2S Replacement Bulbs.
Hid replacement bulb for factory H.I.D. cars. 2 Bulbs.
5000k white
6000k blue
2 Pieces. 70.00
Replacement Hid bulbs for cheaper burned out 9005,9006,H11.
Will work with most 35 watt kits from other companies. Any color range. Plug and play.
2 Pieces. 70.00
Front fender turn signal, and Headlights.
2 Peices. H11 Fog light LED's.
136 LED's total. These are the brightest made on the market. Technology has made them almost as bright as the stock bulb. They have a great 5500k hid look. 100 times better looking than a stock bulb without the cost, hassles, wiring of a H.I.D. kit.
They are a great match for HID headlights.
65.00 Shipped
2 Peices, 194 Headlight parking light.
Amber, White, Red, or Blue, 19.00 Plug, and enjoy.
Or
25.00 for the Hi-Po. Brightest and biggest that will fit in the housing without melting it.
7440 Headlight turn signal.
Red, White, Blue, or Amber. 2 Peices.
Brighter than stock. Plug, and enjoy. Requires load resistor, see below.
6, 1 watt leds 25.00.
Or
Super bright version, 7440, 96 leds
50.00
Or
75.00
Load resistors.
2 Load resistors, 25.00 Plug, stick, and enjoy. Install instructions included.
5000k white
6000k blue
2 Pieces. 70.00
2 Pieces. 70.00
65.00 Shipped
Or
Or
50.00
Or
75.00
Load resistors.
can you make up some sort of enclosure with a bunch of 3 watt led's to go across the vent the stock fog lights sit in?
i think a bunch of 3 watt's would def be bright enough to replace the fog lights
someone did this already, but i would rather just buy a premade set
