turbo timer q
Old Dec 10, 2008 | 01:35 AM
MitsuEvo05's Avatar
turbo timer q
i just installed my greddy turbo timer and just outta curiousity, this maybe a noob question, when the timer goes off is the alarm suppose to turn on by itself or do you have to wait there then turn on the alarm on your own? and what did you guys use to mount your tt?
Old Dec 10, 2008 | 01:56 AM
whoang40's Avatar
My Blitz Fatt turbo timer doesn't alarm, but flashes red the last few seconds before it turns the car off. I just mounted mine with double sided tape behind the shifter.
Old Dec 10, 2008 | 02:15 AM
NWEvoViii's Avatar
As in alarm, If you're referring to an aftermarket alarm. It will interfere with it. Some people have a problem with the alarm unlock by itself when the turbo timer finishes counting down, or the doors will be unlocked, or some other problem. Usually you would have to arm the alarm after the car finished counting down.
What alarm do you have?
My turbo turbo timer is mounted under the cubby pocket/radio relocation place.
Old Dec 10, 2008 | 01:37 PM
MitsuEvo05's Avatar
double sided tape? i tried using that and it just fell off....
now im using double sided taped velcro.
i honestly dont know what kind of alarm i have, it came from the dealer like this but its used and the dealer said its aftermarket. i cant even alarm my vehicle when the counter is going down i have to wait until it completely ends for me to alarm it. i was wondering if everyone is like that or is there some people who can alarm it and just leave, cause thats what i want
Old Dec 10, 2008 | 05:39 PM
gsrboi80's Avatar
You need to wire it into your aftermarket alarm properly
https://www.evolutionm.net/forums/sh...d.php?t=265895
https://www.evolutionm.net/forums/sh...d.php?t=119316
Old Dec 10, 2008 | 05:46 PM
boostless's Avatar
if its the stock keyless entry, you can lock the car while in countdown
Old Dec 10, 2008 | 09:14 PM
MitsuEvo05's Avatar
the links dont work...its a aftermarket cause it does not lock while countdown
Old Dec 10, 2008 | 11:55 PM
NWEvoViii's Avatar
Links fixed, No offense, But you could have found the error in the links yourself and direct yourself towards the right direction, None the less hope those links help.
Old Dec 11, 2008 | 01:16 AM
HELOVESTEHBOOST's Avatar
Arm the car as you normally would. It's just a turbo timer not Alfred from Batman.
Old Dec 11, 2008 | 06:34 AM
gsrboi80's Avatar
I fixed them in my post too. Thanks man
