How much power will my setup make [Mega Merge]
Please post in this thread to discuss how much power your evo will make on some setup. Any other threads started on this subject will be trashed.
Disclaimer - No person can accurately know what a setup will make on different cars. Please assume everything is an assumption and should be taken with a grain of salt.
Thanks,
MR Turco
hello everybody hope you are fine. i own a 2003 evo8 and live in Pakistan. i have ordered some stuff and was thinking that how much hp will it produce on its max boost and approx how much time it will it be in quarter mile. Here in Pakistan we dont have a dyno so all tuning will be done on road. we have 91 octane here and temp is around 30 degree celcius. the list of my stuff is as follows.. plz dont spoil my thread bec i need guidance from you people because i am new to this modification stuff. thankx alot waiting for your replies.
1.TURBO PRCESSION 6265
2.TWIN SCROLL FULL RACE MANIFOld
3.FULL RACE DOWN PIPE
4.WASTE GATE TWIN 44MM
5.precision INJECTORS 1200CC
6.POWER FC DEJETRO WITH COMMANDER & SENSORS
7.SLIM FAN
8.ETS INTERCOOLER
9.CAM SHAFT SET kalford 280
10.PISTON SET visko
11.CONECTING ROD manley
12.cometic HEADGASKIT
13.SUPERTECH VALVE SPRING RETAINERS
14.FULL BLOWN TWIN FUEL PUMPS
15.skunk2 intake manifold
16.SPRAKTECK IGNITION SYSTEM
17.DEFI GUAGES 4PCS WITH LINK UNIT
21.MAIN AND CRANK BEARING ACL
22.CAM GEARS SKUNK2
23.ARP HEADSTUDS
24.PIPE KIT ETS
25.hks blow off valve
26.avcr boost controller
27.hks twin clutch
28.greddy evo2 catback exhaust system
29.Tien lowering springs
waiting for replies.
Thanks,
MR Turco
7.SLIM FAN
8.ETS INTERCOOLER
10.PISTON SET visko
22.CAM GEARS SKUNK2
23.ARP HEADSTUDS
24.PIPE KIT ETS
27.hks twin clutch
^ Agreed.
It depends on many factors,
Your tune will be a huge factor, is 95oct the same over there as it is here?
How much boost can you run on it before knocking?
Id say if you can find some C16 over there and can run upwards of 30psi it would be in the neighborhood of 600-650whp. But then again im not good at bench dyno'ing. Your part descriptions are very vague so who know what it will be. Only doing it will tell.
some more replies needed please so i can get an estimate that my car will be like what whp? and can anybody tell that approx how much time will it be on quarter mile. anyone who knows about this stuff will be able to answer my question better. thanks for replies bro
waiting for more.
waiting for more.
we here have 93 octane which is the normal fuel and the other is 95 which we call the hi-ocatane. hi-ocatane is used in sports cars. ( i mean its considered as a better fuel )
1 Post
Also consider which dyno you're gonna pull your car on. Mustang to Jet, the numbers will look real different, so that's another consideration you should remember as well.
You want butt numbers, Mustang or a Dynamics. Want some bragging numbers Jet.
