For Sale - Part Outs Parting out your car? Place it in here.
FS[MidWest]: evo 8-10/dsm parts-Fidanza,Perrin,APR,FIC,carbon!!
Old Mar 30, 2016, 12:48 PM
ryukinevo's Avatar
Post
Hi evo 8-10, dsm, lancer, ralliart owners! Sold a lot of my aftermarket/oem parts from my current evo 8.5 build and this is what I still have for sale, see my itrader feedback! I paid a lot of money through the course of this project; my loss is your gain!
  • Parts are ready to ship after paypal has cleared, usually same or next day! pm for paypal address after agreement to purchase part.
  • PRICES DO NOT INCLUDE SHIPPING OR PAYPAL FEES and I will only charge actual shipping cost with insurance via usps, Fedex, UPS, or Greyhound for the larger items. Please be serious upon purchase before asking for shipping quotes!
  • If a price is out of line with the market prices, do not be afraid to make an offer. However, I have done the research and believe these are accurate evolutionm going rate prices. The worst thing is that I would say no!
Please contact Scott via pm or cell #
http://www.hidetext.net/hide/mMaqGfFqy9.gif
Please see my local craigslist for evo or Honda parts:
Flickr for all pictures not displayed in this post:
https://www.flickr.com/photos/114062579@N08/albums
  • Power Stop front rotors (near new, less than 500miles) - $150
  • Hawk rear pads (2k) - $75
  • 2 AEM serial guage (2 BNIB, 1 only hooked up not used) - $175 each - CURRENTLY NOT FOR SALE UNTIL TUNE
  • Radiator stays (red, scratches by bolt holes) $15
  • dimple oil drain plug (Used 1 oil change) - $30
  • Precision Turbo PTE6262 .82A/R 5 bolt turbine housing - Tirado Custom Coatings gold ceramic coated BNIB (TCC does perfect work, but 3 month wait) - $150
  • FIC fuel injector seals (Used less than 2K with 2150s) - $20
  • APR GTC-200 carbon fiber side plate (AA-100048) BNIB - $45
  • MISHIMOTO evo 8/9 radiator hose (20K, red upper only) - NEED PRICE
  • Samco evo 6 radiator hose (20K, red lower only) - NEED PRICE
  • evo 6 upper radiator hose (460miles, straight,black) - NEED PRICE
    Universal evo parts:
  • ALTEC PRODUCTS Show-N-Go motorized front license plate w/ remote BNIB - $100
  • Rockford Fosgate positive battery terminal (gold 'R' shape, 1 nut was replaced) BNIB - $30
  • Rockford Fosgate negative battery terminal (gold 'R' shape , less than 50miles) - $25
  • Ichibahn valve stem caps (yellow) BNIB - $8
  • Pilot led side marker lights BNIB - $20
  • Lightning Audio 1 farad capacitor BNIB - $40
  • -8AN braided stainless line (w 1 new Fragola -8 straight fitting (black) not yet installed) - $30 - CURRENTLY NOT FOR SALE UNTIL TUNE
  • rear evo 8 O2 sensor (52K) - $35
  • rear evo 8/9 O2 sensor (mileage unknown, same wiring as evo 9, but wires pinned different (either 05 evo 8 or early evo 9) - $35
  • 1 PERRIN tbolt 225 (2.25") clamp - $5
  • 2 BREEZE tbolt 300 (3.0") clamp - $3
  • 1 BREEZE tbolt 288 (2.88") clamp - $3
  • Hose Techniques silicone 2.5" 90 degree coupler (red) BNIB - $20
  • Silicone 4" to 3" reducer coupler (black) - $5
  • NASCAR carbon fiber 4" to 3" reducer - $20
  • APC Super White 1157 bulbs BNIB - $5
  • Spider lite led bulbs (red) 7443 BNIB - $20
    oem evo 8/9 parts: 42K or 52K miles unless noted otherwise:
  • evo 9 valve cover (unmodified oem) - $230
  • evo 8/9 starter (52K, new aftermarket solenoid) - $75
  • evo 8/9 O2 housing with spring bolts (42k) - $60
  • evo 8/9 front strut bar - $40
  • evo 8/9 Gates blue serpentine belt (Mounted 1 time, 0 miles) - NEED PRICE
  • evo 8/9 oil pump balance shaft with bolt (42k) - $25
  • evo 8/9 balance shaft (42k) - $20
  • evo 8/9 rear dog bone mount (50K) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 exhaust hanger (52K) - $5
  • evo 8/9 hood prop - $10
  • evo 8/9 front engine mount bracket - $15
  • evo 8 rear bumper metal bracket - $10
  • evo 8/9 upper radiator hose (52k still good) - $5
  • evo 8/9 lower radiator hose (52k still good) - $5 - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 radiator brackets (No rubber) - $5
  • evo 05'/06' ACD computer (mileage unknown) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • rear evo 8/9 O2 sensor (mileage unknown, either 05 evo 8 or early evo 9) - $35
  • 2 evo 8/9 fuel assembly float (mileage unknown) - CURRENTLY NOT FOR SALE UNTIL TUNE
  • evo 8/9 cd player (25k) - $25
  • evo 8/9 battery fusible link (52K) - $45
  • evo 8 dash harness (52k, some wires patched into for alarm, easy fix!) - $130
  • evo 9 dash harness (SOLD AS IS: same above evolutionm vendor) - $100
  • 3 evo 8/9 horns - $15 each
  • evo 8/9 EGR valve (42k with bolts) - $25
  • evo 9 oil pressure switch (42K) - $10
  • evo 8 firewall relay (52k) - $15
  • evo 8/9 front brake lines (52k) - $20
  • evo 8/9 rear brake lines (52k) - $20
  • evo 8/9 fuel pressure solenoid (52k) - $25
  • evo 8/9 fuel feed line (42k, hose extended) - $10
  • evo 8/9 undertray (center panel only) - $25
  • evo 8/9 brake dust shields - $30
  • evo 8/9 vacuum bracket (valve cover) - $5
  • evo 8/9 vacuum bracket (large) - $10
  • evo 8/9 wiring bracket (valve cover) - $5
  • 2 evo 8/9 intake manifold brackets (with bolts) - $5 each
SOLD:
  • evo 8/9 front crash beam brackets $25
  • Power Stop rear rotors (near new, less than 500miles) - $150
  • Passport/Escort Direct Wire Smartcord (79-000041-01 - red) - BNIB $25
  • evo 8 turbo coolant lines - $25
  • Fidanza cam gear (black) (2K) - $75
  • evo 8 engine harness (52k, was uncut harness, but due to evolutionm vendor sold undisclosed damaged evo 9 harness - had to cut 1 wire harness and 1 wire needs re-soldered - most likely easy fix!): - $200
  • evo 8 chassis/headlight harness (52k, uncut/unmodified) - $130
  • 2 evo 9 chassis/headlight harness (SOLD AS IS: evolutionm vendor sold undisclosed damage/modified harness) - $100 each
  • evo 8/9 power steering reservoir (52K) - $30
  • evo 8/9 radiator overflow tank (w/hose) - $25
  • Quartermaster 7.25 clutch (near new rebuild, less than 460miles) - $600
  • AMS cross member (Part discontinued from AMS, bought from AMS, used on original AMS drag car, new red powdercoat, less than 460miles, does have slight bend so takes extra work to remove and install) - $200
  • AEM series 2 evo 9 ems/computer (bought from awddyno <3K) - $1150
  • 1 set evo 8/9 oem radio brackets (some screw holes) - $10
Aftermarket: (3k) miles
UNIVERSAL
evo 8/9 oem (42K) or (52K) miles
evo 8/9 wiring/electrical
evo 8 dash harness (52k) - $130
evo 9 dash harness - $100
http://www.flickr.com/photos/114062579@N08/11867245084/
ryukinevo is offline
Old Apr 1, 2016, 10:22 AM
ryukinevo's Avatar
New post!
Old Apr 2, 2016, 06:10 PM
ryukinevo's Avatar
Bump!
Old Apr 3, 2016, 11:43 AM
ryukinevo's Avatar
Bump
Old Apr 3, 2016, 07:31 PM
lowboost's Avatar
do you have pistons available for sale? (in good running condition)
lowboost is offline
Old Apr 4, 2016, 01:52 PM
ryukinevo's Avatar
Bump, all pms replied!
Old Apr 5, 2016, 02:21 PM
ryukinevo's Avatar
Bump
Old Apr 6, 2016, 02:24 PM
ryukinevo's Avatar
Bump
Old Apr 7, 2016, 03:29 PM
ryukinevo's Avatar
Bump
Old Apr 8, 2016, 11:47 AM
ryukinevo's Avatar
Bump
Old Apr 9, 2016, 03:08 PM
ryukinevo's Avatar
Bumpppapp
Old Apr 10, 2016, 02:14 PM
ryukinevo's Avatar
Bump
Old Apr 11, 2016, 10:34 AM
ryukinevo's Avatar
Bump
Old Apr 12, 2016, 11:25 AM
ryukinevo's Avatar
Bump, front crash beam brackets sold to PR.
Old Apr 13, 2016, 11:39 AM
ryukinevo's Avatar
Bump
Quick Reply: FS[MidWest]: evo 8-10/dsm parts-Fidanza,Perrin,APR,FIC,carbon!!
