For Sale - Part Outs Parting out your car? Place it in here.
[FS] Garage/Basement Sale- OEM, Aftermarket, Interior, Engine, Exterior ect.
Old Apr 12, 2017 | 08:09 PM
TeachersEvo's Avatar
Everything came off my personal Evo 9. It was all pulled in useable running condition unless noted. All located in Oregon, will ship everything listed somehow/someway.
I want this crap gone, and more importantly my wife does. Feel free to make an offer and everything is OBO.
Prices include paypal fees but NOT shipping. In most cases, I'll eat the shipping too,
but for bigger items we'll need to work things out.
Just ask for more pics
Price List:
Cluster surround- $10
Complete column surround with broken rear mount tab- $20
Bottom half column surround- $10
Glove Box- $20
Cam Gear Cover- $20
Intake Mani/ TB (no tps, no BISS/IACV, has EGR + emissions sensors)- $75
Evo 9 Upper Rad Hose- $10SOLD
Radiator; pulled working just fine holding pressure for a sexy lady named Koyo- $100
Driveshaft; works great and smootly; good CV's; went to a carbon 2 piece- $115
Front Torque Mount- $10
Coolant Reservoir (bought new and used for like 5k miles) - $20 SOLD
Stock intake tube- $15
Fujita F5 Intake and MAF adapter- $30
Serp Belt Tensioner Pulley (replaced all pulleys including this when I did my Tbelt... should be okay. My timing tensioner took a crap so I'm sure that's the noise I heard. If this isn't right I'll give you a full refund and you can keep it) - $20 SOLD
Factory Turbo to Ex. Manifold Gasket- $10
Factory Downpipe Gasket - $10
Fuel Rail- $10
Evo 9 ECU- $100 SOLD
Factory HLA - $10
Mitsu Oil Cap- $10 SOLD
Relay: MR514694 / 156700-2440 (used for injectors, fuel pump and some other BS IIRC) - $10 SOLD
Factory Clock- $10
Magnus intake manifold to TB adapters: $25 SOLD
Factory Side Markers; one missing it's lil clip: $10
Factory Clutch Wave Clips (holy **** I've done 4 clutches in these things now)- 5$ lol SOLD
MR Sway Bar, Endlink(s), x2 brackets and bushings (not sure whats missing?) - $20
Door Panels, see pics, ask for more pics if you need other close ups ect- $75 SOLD
Fuel Injector Resistor Pack, cut - $5
Depo 9 MR "JDM" tails; rough shape + crack as pictured- $15 SOLD
Spectre O'Reilleys special intake 3" to 2.5" adapter- $10
Evo 9 Rear Seats as pictured / noted. Dusty, could probably be cleaned very nicely- $100? SOLD
Stock Rear Control Arms- $80
J-Specialty Defi Replacement Fuel/Oil Pressure Sensor x2 (verified working and accurate)- $15 SOLD
Fuel Pressure Sensor Adapter for stock fuel rail- $25
Intake Manifold Bracket and emissions sensor - $5
Cam gear cover
Intake Manifold
Intake Manifold Bracket + sensor
Rear Lower Control Arms
Cluster Surround
Column Surround #1; with broken rear tab
Lower column surround #2
Glove box
Defi Fuel Pressure Sensor and Stock fuel rail adapter for fuel pressure sensor + J Specialty Defi Fuel Pressure / Oil Pressure sensor (verified working and accurate)
J-Speciality Defi Fuel Pressure / Oil Pressure sensor replacement (verified working and accurate)
Serp belt tensioner pulley
OEM Ex. Manifold to Turbo gasket and Downpipe gasket
OEM exhaust manifold
small cracking on the inside as pictured, no leaks.
Cooland reservoir bottle, very good condition
Fuel return line and bulk head fitting
Factory Fuel Rail
Magnus intake manifold adapter pieces
OEM clock
3x Evo wave clip clutch retainers; 1 w/o wave springs
Factory HLA
OEM Evolution 9 MR ECU
Relay; P/N: MR514694 / 156700-2440
Evo saddle pump line for fuel tank
3 diamond oil cap
OEM Sidemarkers
Evo 9 MR Sway bar and endlink (one is bent)
Factory Evo 9 intake
Factory center crossmember transmission torque mount.
Spectre intake thing adapter
Cut injector resistor box
Fujita F5 intake (complete)
Upper radiator hose
Radiator from 9
Depo JDM 9 tails, resealed and crack as pictured
Crack
Door panels
Worst damage on the panels
seat bottom, some spots will need cleaned, lower left corner.
Seat back, dusty
Driveshaft
Yoke
Old Apr 13, 2017 | 05:42 AM
Early morning bump
Old Apr 13, 2017 | 08:36 PM
Up
Old Apr 13, 2017 | 10:53 PM
mattv's Avatar
Sending a PM now...
Old Apr 14, 2017 | 04:22 AM
uneekvisions's Avatar
Originally Posted by TeachersEvo
Up
pm sent
Old Apr 14, 2017 | 05:16 AM
Pm's replied, thanks everyone. ECU, Coolant Res and the Relay are sold.
Old Apr 14, 2017 | 06:20 PM
PM's replied and the list updated. Thanks!
Old Apr 15, 2017 | 06:55 AM
PM's replied updating pending items now as well as things are moving quickly Wife is pleased, keep up the good work gentlemen.
Old Apr 17, 2017 | 05:29 AM
Updated.
Old Apr 17, 2017 | 09:42 AM
Updated. PM's replied.
Old Apr 18, 2017 | 09:34 AM
Up
Old Apr 19, 2017 | 10:03 AM
up
Old Apr 23, 2017 | 08:25 AM
any other takers?
Old Apr 25, 2017 | 05:47 AM
up
Old Apr 26, 2017 | 07:01 PM
up
