Black Built 2.3L w/ BB FP Green
For Sale2003 Mitsubishi Lancer Evolution
Price
$23,000• OBO
- Location Green Brook, NJ, 08812, USA
- Condition Used
- VIN JA3AH86F23U087144
- Mileage 115,000
- Engine 4 cyl
- Drive Type AWD
- Transmission Manual
- Vehicle Type Sedan
- Exterior Color Black
2003 Black Evo 8: Second owner, bought from a doctor back in 2006 with only 18K on it, always garage kept, no dents or dings, current miles on odometer ~115K, some road debris chips to front bumper paint, has been my "weekend vehicle" for the last 6 years
463hp/453tq (attached dyno sheet) - Quick spool, great road vehicle... Easily could swap in a larger turbo. The engine has a lot of room.
ENGINE - Less than 5K on the build
- 2.3L Built Bottom End
- 9.0:1 Wiseco 1400HD
- Manley Turbo Tuff Rods
- Manley 100mm Forged Crank
- ACL bearing set, ARP main studs, Front Case, Water Pump, Balance Shaft Eliminator Kit, Timing Components, Timing belt, Serpentine Belt, ARP 625+ headstuds
- Curt Brown Cylinder head
- Supertech Nitrate coated SS valves
- Kiggly Behive springs
- Race port
- Bronze valve guides
- Competition multi angle valve job
- New seals
- Pressure checked
- EGR port tapped and plugged
- Resurfacing for MLS gasket
- Kiggly HLA
- Ported DBB FP Green w/ 84mm Cover, 25psi WGA, w/FP Line
- Buschur Racing (BR) ported stock exhaust manifold, O2 Housing
- BR Turboback 3" Exhaust w/ cat
- GSC S2 Cams
- PPI ported Intake manifold and 65mm Throttle Body
- Short route Intercooler piping w/ Tial Q BOV (battery relocated to trunk)
- BR FMIC
- Fabricated Intake Pipe
- FIC 1100cc High Z Injectors
- Walbro 255 modded Fuel Pump
- SpoolinUp COP
- Grimmspeed 3port
- Tephra v7 speed density /w ecuboost
- Comp Stage 3 Clutch
- Spec Ops Catch Can
- Swift R Spec Springs
- Evo 9 Front Bumper
- Black housing headlights
- OEM Evo 7 taillights
- OEM Wing removed - stock black lancer trunk (I.e. no holes)
- OEM Evo X 18" rims, Tires: 245/40R18XL 97Y VSB HANKOOK VENTUS V12 EVO K110
- OEM Brembo Calipers, Rotor Pros Slotted Rotors, Hawk HPS pads
- Alpine head unit
- 3 gauge formed dash insert
- Prosport EVO gauges: Boost, Engine Temp, O2
Unfortunately, I moved the car to my parents’ garage (45 minutes away), and I won’t be able to get the verification photo until this weekend. I will update this thread then. Apologies.
