EVO 9 Headlight Restoration Vs New UV Clear Coat
Hey guys, what do you guys use when the headlamps fade? I know there are a ton of threads on this issue but none of them give a straight answer on if these restoration kits can achieve like a brand new oem factor headlight assembly.
I have previously tried headlight restoration kits, but 1) They never look crystal clear like brand brand new, 2) They don't last more than 1 year. Maybe I didn't use the right kit, (sanded 3 different grits, then polished and sprayed a UV protectant), but how do these restoration kits compare to buying brand new ones? I've looked around and brand new they are about $3000 dollars (https://stmtuned.com/collections/mit...smoked-evo-8-9).
Will new ones last for more than 5 years? What do most of you guys use? Do you guys have suggestions on aftermarket parts or cosmetic changes that look nice?
Wet sand with 600 grit sand paper, go up as high as you want but a lot will just use 400 grit and then spray with 2k clear coat. It'll look not so good at 600 grit but it'll come out clear after you spray with clear. You can up the sand paper grade if you want but will come out the same from what I've heard. After you've sprayed multiple coats, wet sand at like 2000 grit to smooth it out to get rid of orange peel and compound/polish to get it super good looking. Will lasts a very long time if done right.
evo8finally (Sep 18, 2018)
I'm also interested in this as well. I use Meguiars Plast-X every few months. It looks good for a while, but definitely is not a permanent solution. I was leaning toward clear-coating, but was concerned about heat perhaps cracking the lenses? I also considered Lamin-X as well. I'd love to hear whatever solution folks are having good luck with!
You will need to apply a coat that has UV resistance for the lens to not yellow. Just get a decent sealant and it should last up to 6 months but I would apply it a little more often. Or the long term solution, clear coat it. If you clearcoat it, the easiest and best one to use is the spraymax 2k clear or a non out of a can clear, any other can crap will not last.
I did this exact thing with a set of lights I had. I had to take it down to 400 grit sandpaper to get the surface level and then worked back up to 1200 before hitting them with some clear primer. After I just hit them with 2 or 3 coats of the Spraymax 2k clear and finished them with some wet sanding and buffing to make them shine like new. The lights looked great even after more than a year of abusive driving I put my car through. The headlight restoration kits or UV sealers by comparison for me have never lasted more than 6 months and often don't even make it 2 months before yellowing starts to appear again.
