JDC Titanium Oil Caps For Evo 4-9 are now in stock! (While supplies last)
The JDC oil cap provides a very tight lock and uses an OEM Mitsubishi gasket for a leak proof seal. Each cap is professionally CNC machined from a single piece of 6AL-4V Grade 5 Titanium and we've incorporated the bottom locking collar into the design and got rid of the screw/nut that would normally be inside your valve cover! Each cap is laser etched with the JDC logo on the center and is hand polished before receiving our custom color treatment.
Benefits of the JDC Titanium Oil Cap:
- One-piece design eliminates the possibility of the screw/nut falling off inside your valve cover, preventing a possible disaster!
- OEM Mitsubishi gasket is used for a tight and long lasting seal.
- 6AL-4V Grade 5 Titanium is super strong and will never rust!
- Available in polished, or our famous burnt finish! Email us for custom options.
- Laser etched logo
Install notes: The JDC logo will be straight facing the front of the engine bay when tightened all the way. If you have any trouble tightening the cap completely you can put a small screwdriver through two of the holes to give you more leverage until the rubber seal fully breaks in. Adding a little oil to the bottom of the seal may also help. This tight lock provides a leak free seal from day one that will last many years!
Each piece is hand polished before receiving our special coloring.
One piece design eliminates the risk of having a screw or bolt fall off inside your valve cover!
Available in polished, burnt, or custom finishes!
Professionally CNC machined for a perfect, tight locking fit every time!
Thanks! A custom finish would be something besides burnt, or polished. I can do solid colors, or a mix of colors as long as they're within the scale that's available for anodizing titanium. I'm not able to do black yet, but I'm planning to offer black on my next batch, which will be ready in roughly 8 weeks.
I do plan to make a few without the logo for the guys (like me) that like a nice, clean bay without logos and names all over everything. I can definitely do one in a raw polished finish for you! If you follow me on instagram you'll be able to keep up with what's going on before other people that don't follow me know. It's easy and quick to contact me there too. @JD_Customs_USA.
JD Customs USA (Jun 25, 2019)
