South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
SRS light on- Need a good Dallas Dealership
Old Feb 7, 2006 | 02:32 PM
nixx's Avatar
My SRS light has been on a few months becuase I tapped my satellite radio box into the SRS wire on the passenger side by mistake. I'm sure I just need the SRS computer reset. What dealership and/or tech would you recommend in the DFW area? I realize some like Fazelli in Mesquite- however I've noticed that dealer attitudes towards modified EVOs change.. Will they throw a fit due to a slightly modified evo?
Old Feb 7, 2006 | 02:38 PM
TxEvo8's Avatar
Have you tried disconnecting the battery for a minute or two?
Old Feb 7, 2006 | 04:51 PM
nixx's Avatar
yeah.. SRS is a separate "system".. I've tried pulling the battery for 10 minutes.. and it doesn't show up in OBDII. I can see and clear trouble codes with my ECU+ and it doesn't show up there either.
Old Feb 7, 2006 | 07:11 PM
Monkey's Avatar
It's the same computer. Disconnect the positive terminal on the batter for 15min and leave the drivers side door open.
If that doesn't work, try Don Herring Mitsu. They will be able to diagnosis it
Old Feb 9, 2006 | 04:44 PM
ez's Avatar
ez
As Monkey said, Don Herring Irving will take care of you if you can get it figured out. The svc mgr is Marty...just tell them NTEC referred you.
Old Feb 24, 2006 | 07:46 AM
DonMitsu's Avatar
Thanks for the endorsement guys!
Old Feb 24, 2006 | 07:55 AM
evopower1021's Avatar
you can pull the light bulb out and then you will never have to see it again......j/k.
