Cam gears in Houston
You can check youself. get a 1/2 drive and turn the crank till one of the cam gears lines up with the valve cover line then check if the other cam gear and see if it lines up too it not then there off. just make sure the white lines on the cam gears match the 2 marks on the valve cover.
FS[South]: Evo 8 engine (Houston)
yositoco
Apr 23, 2016 09:04 AM
