South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
KevinD's new project
Old Nov 10, 2007 | 05:44 PM
Lancerguy'03's Avatar
i duno what car i cant wait to ride in....mine or kevins.....
Old Nov 10, 2007 | 09:01 PM
KevinD's Avatar
Originally Posted by Jspec EVO VIII
You going to run stock block and head?
yup, stock block and head. get this, 30psi with stock head studs too i have the ARPs just in case i get coolant overflow, so we'll see.
the good news is i got all the t-bolt clamps on and successfully boosted at wastegate pressure tonight... 16psi not a single pipe popped off either
i do have a exhaust leak and some major boost leaks though. the meth nozzles aren't sealed well enough so i think i'm going to have some bungs welded in. the exhaust leak i need a gasket for.
Old Nov 10, 2007 | 09:15 PM
bolvangar's Avatar
I got a new welder if ya wanna use it
Old Nov 10, 2007 | 11:24 PM
red evo8's Avatar
some one is busy
Old Nov 11, 2007 | 07:45 AM
dridge11's Avatar
I could totally outrun you in my truck*
*pulling a 4,000 lbs trailer
Old Nov 11, 2007 | 12:55 PM
KevinD's Avatar
well, tuned it for 20-21psi on pump even with the boost leaks and exhaust leak. i went through a 1/4 tank of gas really quickly spool-up is a lot quicker then i thought it would be. i'm hitting full boost by 4500 rpm. not bad for a 2.0L with a 35R once i get my meth tank mounted again, then i'll tune it up for meth and see what she can do.
Old Nov 11, 2007 | 02:30 PM
evomojo's Avatar
Sounds great Kevin. Now that you have a 35r Evo when someone leaves a 35r Evo with you to work on they get a good loaner
Old Nov 11, 2007 | 05:49 PM
JeffMas1587's Avatar
pics?
Old Nov 12, 2007 | 10:11 AM
externaldump's Avatar
Great work Kevin, keep it up. Should be seeing you soon for a tune.
Old Nov 19, 2007 | 06:21 PM
low_psi's Avatar
ridic kevin. i'm jealous
Old Nov 20, 2007 | 06:51 AM
KevinD's Avatar
well i started tuning it with meth last night until the cops shined their spotlight on me while i was in a parking lot with my lights off flashing the ecu. i think the open dump at 12:15 at night made them aware i was in the area...
regardless, i was showing about 379whp on pump at about 20-22psi according to my DLL. with the meth i haven't gotten a number yet but at 28psi my spark plugs were breaking up. i fixed that this morning and it feels very strong... i should be able to increase the boost to 30+ psi and hoping for 450+whp. not bad for stock block, stock head, stock studs... oh, and this is all with my high flow cat in too i still have to pass emmisions testing this week so i need to fix the boost leaks and exhaust leak. the flange and gasket for the exhaust leak is on its way already.
hopefully i'll be able to get a before and after DLL plot up shortly.
Old Nov 20, 2007 | 09:30 AM
you are a mad man way to go.
