South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
Next Don Herring Track Day?
Old Mar 3, 2008 | 05:06 PM
  #46
DonMitsu's Avatar
They are mostly Evo drivers, many of them Don Herring customers, there are still some slots open when they are full I will remove the "Buy Now" link from our web site and will allow a cople of alternates to sign up just in case someone drops out. Apex Driving School is providing the driver training. Until then come to the NTEC meetings every 3rd Tuesday at Spring Creek in Irving
Old Mar 3, 2008 | 08:11 PM
  #47
Lancerguy'03's Avatar
there is still a slot? i should be back from iraq for this. ill probly just show up and hang out.
Old Mar 3, 2008 | 09:56 PM
  #48
chad99evo's Avatar
im up for it
Old Mar 4, 2008 | 07:32 AM
  #49
DEVO330's Avatar
I just like to watch.....?
Just watch the fun?
That doesn't sound like you; sign up even for the waiting list if you have to
Old Mar 4, 2008 | 08:45 AM
  #50
TxEvo8's Avatar
Originally Posted by DEVO330
Just watch the fun?
I think Andrew might be a little scared of his new set up , I'll take that bad boy out on the track for ya!!
Old Mar 4, 2008 | 10:57 AM
  #51
low_psi's Avatar
Just signed up! Can't wait. Gives me plenty of time to buy new goodies.
Old Mar 4, 2008 | 08:15 PM
  #52
what are good brake pad replacements??? Hawk HPS? also im torn between BFG KDW and Bridgestone Tyres....like the Potenza RE050A Pole Position or RE-01R, witch i dont think i quite need....help....
i need some good tyres that handle good all the time...just throw out suggestions...
Old Mar 4, 2008 | 08:26 PM
  #53
low_psi's Avatar
Is it your first time at a track? If so, use whatever is on your car now. And turn the boost down
Old Mar 5, 2008 | 04:21 AM
  #54
no its not my 1st time and the stock advans are pretty much done.......
Old Mar 5, 2008 | 05:25 AM
  #55
mt057's Avatar
It is going to be my first time. This sounds like fun. I guess I should practice my wave by
Old Mar 5, 2008 | 08:01 AM
  #56
TxEvo8's Avatar
I'm going to try those Re-01Rs next, I think that you would be disappointed with the other selections that you mentioned. I've run two sets of the Falken 615s, and they are pretty good...
Old Mar 5, 2008 | 08:44 AM
  #57
yeah i narrowed it down the RE050A PP and the 615s, just doin more research but i think the 615s might win on price, but the bstone is on sale for 150/tire on tirerack.com.....i think the re01r will wear to fast for what im lookin for...and whats brake pads? hawk hps or hs+?
Old Mar 5, 2008 | 12:03 PM
  #58
TxEvo8's Avatar
I'm on my second set of HPS, but Kelly just installed the HP+ and likes them so far, how soon do you need to make a choice on the pads?
Old Mar 6, 2008 | 04:58 AM
  #59
i should get home may 1st....so i got a 2+ months before gettting pads.
also im going to try the RT-615s for my next set....cant beat that price. what size did you run?? im going with the 255/40R17
Old Mar 6, 2008 | 08:51 AM
  #60
DEVO330's Avatar
I assume you're on the stock rim;
I ran 2 sets of 255 on 17x8.5 (stock rim 17x8) (615 and KDW2)
both performed great until I took them to the track.
They were too wide under track conditions, regardless of the air pressures.
Mitsu knew what they were doing when they had Yoko build 235s,
they are the best size for high performance response and handling.
although, you'll lose some accel unless you go to a wider rim/tire match-up
Pads: Its been a quest to find something for street/MSR(harder'n most tracks)
I'm always up for learning something new, improving my driving style...
but I seem to have a continual pad deposit problem on my rotors. I over heat the pad and that leaves material on the rotor which feels like a warped rotor.
Recently i switched to HP+ on the street and track. So far, they have not squealed, and have worn thru the prior pad deposits left from the Ferrodo2500.
that makes me optimistic for the track, but they are wearing the rotor more rapidly too....
Haven't used them heavily on the track yet, I've been playing w/Miata
