South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
licp keeps poping off???
Old Oct 7, 2008 | 02:41 PM
Turbo Kyle's Avatar
Originally Posted by booster9
lol well i didnt heat them up, this was probly a terrible idea, but i put wax on the end to make it slide on easier.. but i installed it like 4 weeks ago, jsut did the tune today.. it never poped off stock
Use alky as a lube after you clean everything. It will dry and stick....if you really wasnt to get after it, spray hair spray on it for some extra stick.
Old Oct 7, 2008 | 02:44 PM
GTisRule's Avatar
T-Bolt clamps are stock items at most Napa Parts stores starting at 2.5" They run $4.95 a clamp. I've bought about a dozen from the local Napa's around here.
Old Oct 7, 2008 | 02:47 PM
ASIXMRSE's Avatar
RRE has All the clamps you need as well.
Old Oct 7, 2008 | 03:03 PM
booster9's Avatar
Originally Posted by chad99evo
i can sell you my extra 2.5" t-bolts. all you will need is a 3" for the throttle body and 1.75 for the j-pipe to lower ic pipe. or you can just order them from treadstoneperformance.net or .com. its 3$ a clamp and $5 for silicone couplers. I'm running 29 psi and have no problems what so ever. total cost, $55.00 shipped. for all tbolts and cew couplers
thanks! i still have stock uicp. apparently its not restrictive at all so ill just keep it even tho its hidious. the only coupling i would need and clamp would be to connect the IC to the LICP. but if i buy a new IC then i wont need it so, well see
Old Oct 7, 2008 | 03:36 PM
nikkadanny's Avatar
does anyone know the size of the stock intercooler coupler?
Old Oct 7, 2008 | 04:51 PM
evotom's Avatar
the couplers size are 2.5" danny and upgrade it to the silicone one its stronger and wont pop off like the stock rubber one.. i had that happen to me alot until i got new silicone couplers and T-bolts
Old Oct 7, 2008 | 07:17 PM
nikkadanny's Avatar
thanks tommy, should i get a 45 elbow or a straight?
Old Oct 7, 2008 | 07:45 PM
evotom's Avatar
45 cuz ur FMIC looks like the stock so ur gonna need that... i know this one site that i bought it from its really cheap too and the T-bolts. 10 T-bolts for $20 let me look for the site when im home, got it save on my favorite
