South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
HELP!!! possible water in motor
Old Apr 19, 2009 | 09:43 AM
bmojito's Avatar
Exclamation HELP!!! possible water in motor
i ran through a large mass of water trying to get home. I took off my intercooler and piping and got all the water out of them which wasn't much. I got new plugs and gapped them to the right gap. The car runs fine up until 15lbs of boost now it starts to pop chug and the boost fluxuates like crazy. I can still hit taget boost 20lbs. but it fluxuates from 20 to 15. i got it scanned today and only came up with cylinder 4 missfire, and 02 sensor dead (that's been dead forevor), i changed the coils around and drove it and it still picked up the cylinder 4 missfire. I'm confused.
Old Apr 19, 2009 | 09:47 AM
SLO-EVO's Avatar
go to the store and put 1/3 gas tank, 1/3 valve cover, 1/3 intake manifold... have saved too many motors to count... good luck...
im not advertising this product or selling it...
Old Apr 19, 2009 | 09:48 AM
JakeTheVIII's Avatar
Hmm....Sounds like it would be a little worse if there was actually water in the combustion chamber(s), especially if you're still nailing 15-20lbs of boost. Try some other things to narrow it down, boost leak test, leak down, log it, etc.
Old Apr 19, 2009 | 09:56 AM
bmojito's Avatar
boost leak test turned up with nothing. will do leakdown tomorrow and i can't log i lost my cable.
Old Apr 19, 2009 | 09:10 PM
hellcat's Avatar
pull the plugs crank it and see if water jets out of the spark plug sockets.
Old Apr 20, 2009 | 09:33 AM
Evo_Someday's Avatar
Since the engine runs, and boost is working up to 15 lbs, how could there possibly still be water sitting in the combustion chamber? It would have been long since forced out the exhaust port -- don't you think?
Old Apr 20, 2009 | 09:41 AM
cvnick's Avatar
check your compression you might have bent a rod in cylinder #4 which in turn may be causing your misfire due to low compression.
Old Apr 21, 2009 | 03:02 PM
bmojito's Avatar
well guys i did a compression check today and came out with good numbers across the board! one of my suby friends told me to check my maf, he said same thing happend to him before and it tripped out the maf. so i checked it out and voila! nasty stuff all over it. i cleaned it with cotton swabs and alcohal. it now runs like it did before. thanks fot he input guys.
Old Apr 21, 2009 | 06:18 PM
meckert's Avatar
recheck the gap on your plugs
Old Apr 21, 2009 | 06:44 PM
Hahah.. check the post right above...
