Wts '06 ix se
Wts '06 ix se
WTS 2006 Evo IX SE . Graphite Grey Black with red stitched interior
65k miles
In Short:
Fast as a GT3 RS on MSR / TWS
http://s126.photobucket.com/albums/p...ompmsr9808.flv
http://s126.photobucket.com/albums/p...08yellow-1.flv
450whp(25psi)-500whp(30psi)
Mods:
SD setup, (can still use MAF with simple reflash)
e85 / 93oct map switching setup
fully built motor
ETS 3.5" FMIC
LICP, Upper Samco hoses with all Tbolt clamps
FIC 1050 injectors
Turbo Trix fully ported head 1MM over sized valves
fp4R cams with upgraded retainers /springs
EvoRed turbo
QM Twin 7.25 clutch with light fly wheel
3" Megan exhaust (3" ID from turbo outlet to rear muffler)
Megan Racing Track Series Coil Overs.
PF 2pc Floating front rotors
Custom air guides (to cool above on track @ 450whp)
Perrin RSB with mounts
Dayton Sensors Wide Band that feeds into ECU for logging plus in car display
AEM Digital Boost gauge (also boost controller that is unhooked due to ECU controlled boost)
Harness bar
Team Tech 6 point padded race belts
I am 2nd owner of the car. Purchased with 20k mile on car in May 08' Car had 0 mods on it when I bought it. ALL of the mods above have been installed, and tuned by Evolution Dynamics (and or Laramie <3 ).
Will be happy to answer any serious questions or give test rides. Cash in hand gets test drives (unless I really know you.) Thnx for veiwing!
$24,500.00
65k miles
In Short:
Mods:
fully built motor
ETS 3.5" FMIC
FIC 1050 injectors
EvoRed turbo
Harness bar
$24,500.00
standalone
Oct 3, 2013 09:11 AM
Tiradocc
25
Apr 10, 2011 10:06 PM
EvolutionTime
22
Apr 22, 2010 08:38 AM
