South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
SSP TX is the TOPS!!
Old Jan 11, 2012 | 06:52 PM
EvoLeoIX's Avatar
Hello peers. Ive had the pleasure of having my car serviced and upgraded by the professionals at SSP TX. There are plenty of shops in southern california that knew how to work on evo and were trustworthy, but when I moved back to Texas I had to hunt for the right shop for me. I've bounced around the area for a great mechanic and ended up trusting a subaru guru, becuase the rest of the Evo mechs in houston were falling short.
Then SSP opened their doors and i've been a loyal customer ever since. There are many so called specialists in the area, but when I say that these guys are professionals, I mean it.
Thier shop is truley "a shop" with lifts, a fabrication section, a clean room to build engines and a reliable new AWD mustang dyno.
They understand customer service and stand by their work.
Anything from an extensive engine build or transwork to the simplest job of fluid changes, these guys have you covered.
Ive been in for a clutch master cylinder, 90k service, new clutch, and most recently, their proven SSP oil catch can.
Check out my write up here:
https://www.evolutionm.net/forums/ev...-8-9-10-a.html
Eric is the only person I'd allow tune my car outside of california and David knows evos and mazdas better than his own family.
If your in the Houston area or not, give these guys a shout, you wont be dissappointed.
