South Region Includes AR, LA, MS, NM, OK, TX, NE, KS.
ECU programming?
Old Aug 21, 2004 | 10:44 AM
tweekscratch's Avatar
ECU programming?
What is envolved with reprogramming the EVO's ECU? My experience is with RX-7's, which don't really lend themselves very well to tuning. You basically purchased a piggy back computer similar to the XEDE. Does the EVO's ECU allow a tuner to just plug-in and change variables?
I ask becuase I'm making my plans for the fall. I want to bring my car up to about 300WHP safely. This appears to be a pretty low target for the engine. I just want to know the best way to get there. Should I shell out for a XEDE, or can the stock ECU be reprogrammed well enough to achieve my goal for less mula?
TIA
Old Aug 21, 2004 | 09:05 PM
asasin79's Avatar
the stock ecu can be reflashed, but if you plan on doing it yourself you need http://www.technosquareinc.com/products.htm the trchtom hardware $1500-2000. or you can send it out for flashes everytime you do a mod. or you can get the xede or similar piggyback that controls boost, a/f and timing. you could expect to make 285-295 on a vishnu stage 1 on the local dynos. if you put cams in you should make around 320. i really can't comment on other setups. hope this helps.
vincent
