Boost Issues: Need some help!
Old Oct 5, 2004 | 01:01 PM
jotan82's Avatar
hey guys...
i got my boost controller installed by XAT and they did a slap job half a$$ job. my car has never felt the same since...
my car is boosting 11-12 PSI max with occasional boost spikes to 15 lbs but that's it...
where can i take my car, or can someone take a look at it for me to see if everything is done correctly?
i'm in the orlando area and need some help
thanks
Old Oct 5, 2004 | 01:21 PM
jotan82's Avatar
give me a call please if you have any advise or can lend a helping hand 407 493 9168
Old Oct 5, 2004 | 01:27 PM
chinto's Avatar
what type of boost controler ebc or mbc and try doing a search for that type or if its a apexi avc-r i can probably answer most of ur questions. if not if its a mbc i should beable to help u make sure the hoses are ran correctly.
Old Oct 5, 2004 | 07:12 PM
jotan82's Avatar
well, that's the problem, i'm kinda a turbo rookie, and i had some shop install it, and i feel as though they did s half a$$ job. that's why i need help
it's a greddy e-01 EBC
Old Oct 5, 2004 | 07:24 PM
Evojun8's Avatar
i just got mine done alil while ago. it feels bad *** it doesnt taper. i have 1.4 bars right now. the only promble i had was. when i got out of the shop i was running 1.6 bars i barly punched it and i heard a loud pop. it was the intercooler hose. i tighten it, and then i lowerd my boost. is 1.6 bars to much.
Old Oct 5, 2004 | 09:33 PM
vletnguyen's Avatar
eh bro. i had the same problem when i installed my mbc. should be the same though. i reversed the lines going into the boost controller.. since yours is an electronic with solenoid.. check and try switching those lines.. i think i runs with the oem solenoid.
btw mine didnt boost above 12psi until i switched it. the boost controller wasnt mark with in or out so i wasnt lucky on the first try.
