Sound Sensations Evo Discounts!!
Old Nov 16, 2005 | 08:57 PM
an0ther's Avatar
Just letting everyone know I setup an evo account at my work that any evo owner can use. You will recieve discounts on products, some greater than others. I am the lead installer/asst bay manager and will personally do all the evo's that come in. Just come in and ask for Jon. I know the evo inside and out and at my shop we can do radios/amps/alarms/gauges/suspension/turbotimers/minor engine work/etc... I have been installing for 13 years and take extreme care of cars. I have already worked on countless evom members cars and they are all extremely satisfied!
My evo special this month is a full featured Compustar alarm. This is one of the only alarms on the market that is safe to do remote start on a manual transmission. It comes with a 2way fm remote that has incredible range and will tell you exactly what is going on with your car. It will show you if a door/trunk/hood is opened, it tells you when its running, tells you if someone bumps into the car. There is even sensor in the window that says "RPS remote paging system" that someone who needs to talk to you or ask you about your car can lightly tap your window with a key and it will put a phone icon on the remote and let you know someone is paging you. With this install you get the alarm/1 fm remote/1 standard non 2way remote/shock sensor/door hood trunk protection/keyless entry/flashing parking lights/starter disable/2 blue led's/remote paging system/built in turbo timer/remote start/556UW Dei part to get past the chip in your key when remote starting. We give a lifetime warranty on all installs done in the shop. I had one of these on my 04 evo and in the process of putting it on my new 06. I have installed 6 of these in other evo owners cars already. Keep in mind that you will have to lose a key when we do this. We have to put the key inside the 556UW box to bypass the chip when remote starting. I usually suggest having 3 keys, that way you have 2 after we are finished. I can at the customers request cut the key head off the key so that if someone towed the car and tore it apart they could not use the key that is in that box. I highly suggest this even though it is an expensive key. We also sell the keys at my work, they are around $100 which is about the same as the dealer. Cant work much with those as we have a subcontract with a key maker.
Our normal price is $775 installed
Evo owners and ONLY on Evo's $649 with parts/labor etc... done by me of course
You might be able to find this a little cheaper somewhere, but trust me, I am a VERY clean installer and you will look under the dash and will not see a single wire and I also solder every wire so there is no way of ever having a bad connection.
If you have any questions or comments feel free to shoot me a message or call the shop at 770-429-1600. For those of you who do not know where we are, we are 1 block south of the big chicken.
