Sunday test and tune results
Old Oct 1, 2006 | 05:33 PM
bigric09's Avatar
Talking Sunday test and tune results
hey guys, went to the track today to test and tune for freaky friday coming up... here are my times... there should be some video to follow when krazirob posts it. Thanks to freshsrt for helping with the tuning suggestions....
front 26 psi rear 33 psi
reaction: .76
60ft: 1.74
1/8: 7.73
1/8: 88.97
1/4: 12.06
1/4: 113.35
front 28 psi rear 31psi
reaction: .68
60ft: 1.71
1/8: 7.76
1/8: 88.44
1/4: 12.12
1/4: 112.73
frnt 28psi rear 31psi
reaction: .69
60 ft: 1.76
1/8: 7.85
1/8: 88.11
1/4: 12.18
1/4: 113.98
not too bad... it was fairly warm also... i think friday i can hit an 11 once i lean out the tune a bit more and its a little colder. i also have a boost leak somewhere from my cold side of my IC to the throttle body. i think its the upper pipe. should be trying to swap that out shortly to see if that it or not.
Old Oct 1, 2006 | 05:44 PM
E VOL IX's Avatar
Hell yeah ric you should finally hit 11's friday.. hopefully I will too... Ive only ran at rockingham once tho.. This will be my first at FF.
Old Oct 1, 2006 | 05:46 PM
bigric09's Avatar
it will be nice, hopefully we both will, did you get where we are meeting up at ? PM cirrusly evolvd for the directions, i hope you guys can get down there that early... i also want to get with you to see your tune so i can compare the two... hopefully will be a good night.
Old Oct 1, 2006 | 05:51 PM
E VOL IX's Avatar
Yeah everytime i have went to FF i never get down in time too met up with you guys.. Always waitin around for them damn friends of mine to decide if they wanna go or not.. We should be comin down pretty strong from fuquay this time tho. Yeah that is kool if you wanna check out the tune.. Al said it was one of the stronger IX's he has tuned. He used my maps for about 2 or 3 other mail-ins while i was there. It is WAY WAY smoother than when i was base flashed before on my 12 flat run. Two step never drops below 10 or so. Used to it wouldnt ever go past 5. I had some knock counts from some bad gas but got some nitro methane in it and it took the counts away. Then he bumped the timing back up a little and it is just a freak now. I ran the 1/8th the other night around here and never changed boost from 20 and left the tires at 32 and still pulled off a 7.68 so hopefully I should hit an 11. But me and the other guys are lookin forward to meetin up with everybody on the way down there.
Old Oct 1, 2006 | 06:40 PM
Cirrusly Evolvd's Avatar
Jason, I'm probly ordering my new UICP tomorrow and will more than likely have it by Thursday. If you want you can try my current UICP with the TiAL and see if it helps any.
Old Oct 1, 2006 | 07:40 PM
freshevo8's Avatar
ric, send me your final adjustments on the tune if you made any at all. i need to know your afr's for yesterday, how much boost your running and what fuel mixture your running. congrats on the times and i thought you'd hit a 12.0! if u can nail a 1.6x 60ft i'm sure you'll hit your 11sec. next time drop the front and rear to 22psi and no lift shift from 3-4th.
also, need to know the temps for yesterday and what the temperature has been at night. that also plays a big role in the tune.
Old Oct 1, 2006 | 07:43 PM
ries's Avatar
Jason those are some great times, were these runs on pump or race gas? I think for FF Im going to have to mix and turn up the boost a little so I can keep up
Fix that boost leak and tweak the tune and you'll hit 11's no problem.
Old Oct 1, 2006 | 08:00 PM
Matt, today's high temp was near 80 but it felt a lot warmer than that. Night temps have been in the low 50's. Currently it's 2300 and the temp is around 65 if that helps you tune him for FF.
Old Oct 1, 2006 | 09:10 PM
krazirob's Avatar
well here are the videos of me and jason today at the track..........im on the right and he is obviously on the left. here is the first run and here is the second run cant wait until FF jason.............and i need to get that a/f gauge with a quickness!!!.......lol
Old Oct 1, 2006 | 09:19 PM
krazirob's Avatar
if you click the link and it says that its not available just keep tryin and after the 3rd or so try it will work................first time i used you tube
Old Oct 2, 2006 | 02:03 AM
bigric09's Avatar
thanks for the link rob... for the aem, its coximports as for matt... let him know that brian and i sent ya to him, and im sure he will give it to you for the price he gave it to us, i wont post it on here... but be sure to tell him you are military as well... *** IMPORTS has been very helpful to us. i got my clutch from him as well... from what i hear, he is very knowledgeable when it comes to exedy
