Anyone have a Cam Tensioner Tool? I NEED to borrow it
I got one, thanks Matt
Also, I still have this full RMR turboback here, if anyone wants it, Ill give it to you for 500. Full 3", stainless steel, etc. Very nice system. Not too loud, it has 2 resonators, and a bung for a wideband. I would like to move this system so I have some more money for a down payment on a new car. Thanks guys.
Logan
Logan
Are you talking about the timing belt tensioner? You can make that, I did. There is a write up on here somewhere.
Edit:
And here is a pic of the one I made. AND USE AT YOUR OWN RISK!
Edit:
I use a 36" peice of threaded rod (8mm x 1.25) from a local bolt supplier. It worked great. I put two nuts on the end in a bind and used a wrench when it go to the tensioner arm. This helped keep track of how fast i was going. DO NOT turn fast!!!!! I have the rod if anyone in South Lousiana needs it. Tool would have looked great but the threaded rod was just as effective. It just sticks out alot (don't poke your eye out when working on there.
DIY Rules.
DIY Rules.
