Balanced Performance / Boost Solutions
Old Dec 31, 2003 | 08:25 PM
DynoKing's Avatar
In Timeout
I just wanted to take some time tonight to post this because George took 10 hours of HIS day to help me with my car. If you did not know I had a boost leak with my car, I went to Boost Solutions yesterday at about 11:00am for them to look at my car, 1st George took a look at the hoses then we put the car on the lift and removed all of the plastic’s on the under tray and check all of the hoses and clamps there to make sure it was not leaking from there. Next we put a different stock BOV on the car to see if that would fix it and no dice it had the same problem, we also changed the boost control solenoid and he said he would get a different BOV to test it with tomorrow. Well today I stopped by again @ 11:00 and we tried, 3 stock BOVs, 2 forge valves, and a MONSTER something BOV same deal but the problem did change with each piece, some held better then others but the all leaked. Well around 5 George said let me look at the computer Balanced Performance hooked up, I said sure. We traced all the wires and sure as **** the retards hooked up not 1 but 2 wires wrong, they put a wire that did nothing into the xede for boost control and my idle wire was wrong as well. I paid these people to look at my car and told them I did not care what it cost to get it fixed just fix it. When I left my evo would not idle cold and also the boost was not hooked up, I paid $350 for this sweet *** work they performed and George changed the wires correctly back now it idles and the damn boost control works. I just wanted to post this before any other sucker goes to Balanced to get work done THEY SUCK and there price is higher then anyone else. George fixed 2 things wrong with my car and I am sure we will get this boost leak fixed soon. I would go to Boost Solutions to get ANYTHING done with my car, they are doing the cam gear install as well as fuel pump and anything else that I need done. George took care of me better then ANY shop has done and I had to tell him I had to go because he wanted to work on it more and get the problem fixed not just half *** it and get paid like Balanced did.
Old Dec 31, 2003 | 08:31 PM
DynoKing's Avatar
In Timeout
This is the e-mail I sent to the ****** at Balanced
I just wanted to send you a e-mail say thanks for charging me $300 to make my car worse then stock. I had you guy install cams and a computer on my silver evo 8. The cams were fine but the computer you install totally wrong, the wire for boost control was a wire that did nothing and you also plugged the idle wire in the wrong place as well, I am shipping the ECU out to be tested to see what damage you caused to it I think the stock computer is around $1,600 for this car but I want to see if you damaged it 1st. I will let you know if you damaged the computer on my car or anything else and have my lawyer send you a bill for the repairs. Next time you do some work and say you can do it without any problem please be sure you know what you are doing.
Old Jan 2, 2004 | 02:31 PM
shonuffgd's Avatar
whoa
dag ... sad to hear that bro
Old Jan 2, 2004 | 02:42 PM
DynoKing's Avatar
In Timeout
I will say they said they would fix it for free but after this screwup I don't even know if I want them to look at it again.
Old Jan 2, 2004 | 06:55 PM
Boost Solutions's Avatar
Hei Ryan, we are always glad to help our customers. We are looking forward to see on the meeting tomorow.
Andy
Old Jan 2, 2004 | 07:11 PM
DynoKing's Avatar
In Timeout
I will see you guys then, 10:00 right?
Andy
Old Jan 3, 2004 | 07:19 AM
evoego's Avatar
Registered User
well Ryan tell me whats up then. Still waiting on the e-01 to come in through them. As soon as I get it back, I will decide on where to go from there. I believe they charge too much however. Get in touch with me again please. thanks.
