Stainless Braided Clutch Lines
Old Jan 28, 2004 | 12:48 PM
genimport's Avatar
Talking Stainless Braided Clutch Lines
Hey Everyone!
I just wanted lo let you know that we now have the clutch lines that a lot of you have been inquiring about in stock ready to ship.
We had these stainless braided clutch lines custom made to our spec, because we were not happy with the other ones that we have been seeing on the market.
The biggest difference between our stainless clutch lines and the other ones out there is that ours has extremely high quality fittings AND seals! All of our fittings are stainless! Not aluminum! You don't have to worry about stripping out any threads from poor fittings! We also have super hard plastic sleeve protectors attached to the ends of the line to prevent and kinking or "over bending" at the ends. This will prevent the possibility of any leakage or damage to the seals. Another huge difference between ours and the others is that ours has a thin protective plastic coating over the surface of the braided line to prevent friction and discoloration. This is important because a normal braided surface is not smooth and can rub which can damage the line. Our line has the super slick plastic coating to prevent as much friction as possible. Plus your line won’t discolor from the heat or from getting dirty. It comes with all necessary install hardware and a LIFETIME WARRANTY!
Check out our site for more info http://radicalride.com/Merchant2/mer...ry_Code=TR-EVO
It is really worth making the upgrade!
Tom
www.radicalride.com
Old Jan 28, 2004 | 01:00 PM
genimport's Avatar
Another pic ...I forgot to mention that they also come with the copper washers you need for install. (that is what you see attached to the colored zip ties on the end)
Old Jan 28, 2004 | 02:36 PM
Haste's Avatar
Oooh looks cool.
Old Jan 30, 2004 | 10:29 AM
genimport's Avatar
Bump
Old Mar 30, 2004 | 02:03 PM
WFO's Avatar
WFO
The shopping cart part of your website isn't working for me
