Radio issue
Old Nov 15, 2009 | 05:54 PM
shak's Avatar
Radio issue
driving tonite i turned on the indoor lights an i lost radio signal, turn it off (the lights) and the signal came back, did this for a few times and it was the light. i got home started it up and problem went away (weird) has anyone have or had this issue.
Old Nov 16, 2009 | 06:05 AM
Greedy_son's Avatar
^ Looks like a grounding issue. Check your ground for your radio, try another spot on the car.
Old Nov 16, 2009 | 06:14 AM
shak's Avatar
it is the factory radio though. i will to the dealer tomm an hear wat they say.
Old Nov 16, 2009 | 03:52 PM
evo_soul's Avatar
take it to the dealer and get it documented, so that incase it gets worse, at least there is a trail Way back I had to replace my radio, but for another reason. The volume was jumping up and down, and that was with the auto volume option setting off.
Old Nov 17, 2009 | 08:56 AM
shak's Avatar
went to the dealer today, of course everyting worked fine, had some problems with passenger side window makin noise, they fix that. As i was leaving the radio trbl poped up, took it bak and they heard it fo themselves. they said they have never had this problem before. I have to take it bak, but i have to disconnect all mods, neons, voltmeter etc. in order to rule out that any mods is causing it.
