Opinions on a alarm/remote starter
Hey guys, looking to install an alarm/remote starter on my 09 GT auto tranny....
Ive been debating between the Viper 5901 or the Clifford 70.5x .....any opinions on these two? I know they are made by the same company but does anyone work better with our vehicles....
Now im also wondering what factory immobilizer module is used for our vehicle? I cant find jack shiet for our car....any help is appreciated.
omg ive been looking for this too!!! i need to park my car outside, no garage for me, so kinda looking for something to warm my car or start my car when i wake up ...
i got a GT 2009 manual... any starter for manual too??
I have the 5901. Great system! I have had Viper(DEI) alarms for years, and have them on all my cars. Never had one issue with them. It doesn't matter if you get the Clifford or the Viper, they will both work the same on your car. They are the same system. Did you mean 50.7x ?
But in reality, any remote start will work on a manual. You just risk running you car into something if you leave it in gear and try to remote start it.
I have had remote start on all my manual cars. I never leave mine in gear, it is just a habit. There are different things you hook to the shifter, so it will not start when in gear. Or if your car has a SHIFT light from the factory, then you can use the sensor that is already in your transmission, its super easy.
wait... what??? lol i'm confused...
when i turn off my car i don't leave it in gear. i put it in neutral and pull the hand brake and turn off car ... so with that habit in mind can i still get a remote starter for it? or do i have to do something for it?
i have no knowledge in this so bear with me... all i know is i install something and i press a button and it starts my car. but i suspect that because its a manual that needs to step down on the clutch to start the car theres something special you need to do with it.
Its so much more trouble to put an auto starter in a manual car, Most companies don't make a starter compatible for manual, some do, but if you take it to anyshop they will do one of the following
1) say no
2) f-it up
3) tell you no warranty on install and use at ur own risk
4) charge you an arm and a leg, with the addition of four extra fingers and three toes, and maybe if they are really reluctant a Kidney as well
or if your lucky
5) do it for a reasonable cost
I've had a few shops come and say no to me and others want to charge $1500+
With these cars and all of the electronic glory its a gamble id say, but doesn't hurt to ask around
One time My buddy had a remote start n his Suzuki winter beater standard of course, had his car in reverse for some reason (probably kids playing in it), hit the starter one morning and the car backed out of his drive way across the street through the neighbours garage and hit hit his Lexus.
Any way
Most of the remote starts for standard vehicles tap into the gear sensor and check for neutral position before cranking the car. If your car is in gear then it wont start period
1) say no
2) f-it up
or if your lucky
Any way
there is nothing special you have to do to make any remote start work on a manual, except have it bypass the clutch switch when it starts the car. The remote start does not know if it is in a manual or an automatic.
The remote starts that say they will work on manuals, usually have you do a sequence of things before you turn off the car. They hook a switch to the clutch pedal, so the remote start knows when the clutch pedal is released, also it hooks to the e brake switch.
then you have to pull your e brake, then release your clutch pedal all the way before you turn the car off. This way, the remote start knows it is in neutral, because the car was running with the clutch released. Then the next time you try to remote start it, it will start. If you fail to do the sequence before you turn off the key, it will not let you remote start it later. Make sense?
But there is no need for this if you are **** about leaving it in neutral. It is just a fail safe, and it is good to have it hooked up.
Actually, most cars do not have a gear sensor(beside the reverse sensor). If all cars had an actual gear sensor, then there would be no issue or price difference from shops to install them on any car with a manual. Cars that have a (up shift) light, do have a gear sensor, as mentioned above, and they are super safe to install remote starts in them.
Some shops will hook sensors on the shifter, or cables so the car will not remote start in gear, but if they fail, they are liable, so thats why most do not.
I say just find a friend who can do it, and save a ton. Or an installer who will do it when not at work. I do all of my installs, and all of my family and friends. Saves them a lot of money. LOL
I agree most shops will say no, or charge a lot more. That is only because of liability reasons. They don't want to get sued if you run your car into something, or someone when you remote start it. It is not because it is more difficult to install.
with that said...
1. what brands or products is good for the lancer 2009 GT manual? product names and where to get them?
2. the price range? or prices of the product? i've looked around and some range from like a hundred to two hundred but others go to 500 700 800 because of w/e function they include. so i have no clue if this is even in my budget to do
3. hehe *smily face... smirk actually* hey talon wanna do mine for me??? lol
Here are three 2 way remote start systems. two vipers, and a cheaper brand. All three will do the job and give you 2 way pagers. that is the best to have IMO, because you can confirm that your car actually started.
Here is the Viper 5901. It is there newest and highest model. Up to 1 mile range. It is 220 with 10 shipping, but you would have to see how much for shipping to Canada.
http://cgi.ebay.com/VIPER-5901-RESPO...#ht_1745wt_732
Here is the older model. It has a couple less features, but otherwise it is a great system. It has the one mile range also. You could get this one for at least 50-60 less
http://cgi.ebay.com/VIPER-5900-SST-S...f#ht_500wt_975
Here is a cheaper brand remote start. It is not bad, but the range isn't as good as the vipers, and the quality is not as good IMO.
http://cgi.ebay.com/FM-2-WAY-CAR-ALA...#ht_3911wt_814
I would install it for you no problem. If you were not a million miles away LOL
Here is a bypass module, that does not require one of your keys to work.
\http://cgi.ebay.com/ebaymotors/IB-UMIT-Keyless-Anti-Theft-Bypass-for-Mitsubishi_W0QQitemZ110323814745QQcmdZViewItemQQpt ZMotors_Car_Truck_Parts_Accessories?hash=item19afc fd159#ht_2689wt_866
Here is a bypass module that does require one of your keys to work. It is about half the cost.
\http://cgi.ebay.com/ebaymotors/Remote-Starter-Universal-BYPASS-MODULE-Transponder_W0QQitemZ110458976821QQcmdZViewItemQQp tZRace_Car_Parts?hash=item19b7de3a35#ht_5338wt_958
Talon thanks a lot man....yea the 5901 is the original one i looked at....sonicelectronix is a good place for prices too, incase anyone is looking to do their car stero and looking for a mito 02 box! I just bought one, 150 cdn plus 20 for duties....170 is decently priced compared to some other places!
