Rear Diffuser Group Buy Pickup!!!!!
Old Apr 29, 2010 | 08:40 PM
  #46
evo_soul's Avatar
Originally Posted by seanymack
So my friend and I tried installing it today. what a pain. took hours sanding, drilling etc. poorly made diffuser. not sure if its worth the money but here a few pics. im looking to get it plastidipped soon, and get the mesh installed.
its not poorly made. just the nature of fiberglass. its strongest negatives are slight imperfections coming off the mold, that it needs professional prepping and its fragile. the positives are that its cheap and u can build onto it or around it.
i had my heart broken by fiberglass already
ps plastidip will be here next week.
Old Apr 30, 2010 | 06:24 AM
  #47
T-Pain's Avatar
^ Need plastidip!!!
I found a shop that is willing to install for $150. They specialize in body kits. Not sure if that's a good price or not. Shop is called Eagle Auto.
Old Apr 30, 2010 | 08:25 AM
  #48
mitsubsushi's Avatar
Will they fit it properly and paint it?
Old Apr 30, 2010 | 08:52 AM
  #49
T-Pain's Avatar
^Just plasti dip it and save yourself the money.
They said they can do the fitment and install
Old Apr 30, 2010 | 10:13 AM
  #50
Russkii's Avatar
okay guys I have the solution for the gap, what I did was, I bought a Sponge rubber Tape (10' to be exact) and taped it along the edges, the tape is soft and already comes with a tape or the other side, so you can easily take it to the diffuser, here are the pics, there are no gaps, but keep in mind that the diffuser in the pics is held by Tape, so when you screw it in, it will tighten even more, and will have Zero gaps, The Sponge Rubber Tape was $7 with taxes at Home Depot
Here are the pics
Old Apr 30, 2010 | 05:02 PM
  #51
mk09gts's Avatar
Russkii, can you post more pics after you put the hardware on..thx bud
Old Apr 30, 2010 | 07:59 PM
  #52
heRmzZ*26's Avatar
Originally Posted by T-Pain
^ Need plastidip!!!
where is this place located at???
Old May 1, 2010 | 04:23 AM
  #53
T-Pain's Avatar
^It's downtownish
Queen and Lewis
749 Queen St E
Old May 2, 2010 | 06:55 AM
  #54
charroncp's Avatar
Has anyone used plasti dip in the past? Since it is removable, will it peel off after a while given that this will be close to the ground? I also read that the dirt gets stuck to it easily. I was assuming that the paint it came with would be sufficient, but people are making it sound like it will not be.
Old May 2, 2010 | 07:14 AM
  #55
evo_soul's Avatar
plasti dip is great, but the surface of the lip will need proper sanding and prepping if its course and rough. finally it will have to be clean or (like any other paint) the plasti dip will not adhear too good.
Other then that, it should be great. My estimate is maybe 3 cans of pasti dip.
The price per can will be $13 for this may group buy. and after this next supply is done, the final price will settle to 14 to 15 dollars. The higher price will supplement the ordering of the other colors.
Old May 2, 2010 | 03:08 PM
  #56
recnal09's Avatar
Thanks Russkii for the Sponge Rubber tape suggestion.......however despite that the gap in my car is still very noticeable when you are close (looks good when you are several feet away). To cover this gap further, i've used a black moulding I bought from canadian tire. See pics below.
I got the black mesh from Michaels --- its only 69 cents; it is actually a canvas use for sewing....
Old May 2, 2010 | 03:59 PM
  #57
seanymack's Avatar
looks good bro, i should check that out
where's your muffler?
Old May 2, 2010 | 06:42 PM
  #58
laksman91's Avatar
yea lol, wheres the exhaust tip?
Old May 2, 2010 | 07:03 PM
  #59
recnal09's Avatar
The exhaust tip was removed before I did the diffuser install---it was not the stock exhaust. I just got an axleback Solo Performance exhaust installed last month and it was setup too close to the bumper and hence the diffuser wont fit if the exhaust tip is attached. I need to go back to the muffler shop (Zorro) to re-adjust and lower the exhaust a bit---note: the exhaust tip was actually welded in, the shop had to actually cut the pipe in order for it to be remove.
Old May 2, 2010 | 07:31 PM
  #60
mykee's Avatar
Hey guys if anyone is looking for rear diffuser let me know.
