EVO X billett Actuators
Do you have a new EVO X?
Tired of boost falling off?
We have a solution. The new Forge Motorsports EVO X billet actuator will eliminate boost fading. This actuator will hold a solid 35psi to 8500rpm on a 50trim turbo. Comes equipped with a 15psi spring and will accept stock or any aftermarket boost controller.
This is by far the best bang for the buck on the new EVO X. Bolt on 40whp to the top end of the power band in 15 minutes. The car is 100% safe on the stock tune with this mod on a stock boost controller.
If you are adding a boost controller we recommend you check the AFR with a wideband. If you do not have a wideband, we recommend the AEM UEGO.
Features:
* All billet construction
* Bolts to stock mounts on compressor cover
* Multiple springs for different boost levels
* Turbochargers.com Stickers
$175.00
Features:
$175.00
