Need BOV Recommendation
Old Nov 14, 2004 | 09:25 PM
  #46
Bom's Evo's Avatar
go with a forge dv blue spring. holds 26psi of hot air too...
i usually run 20psi and have zero drivability problems.
Old Nov 14, 2004 | 09:30 PM
  #47
smp3000's Avatar
eeek no no forge. lol I had wayy too much surging and fluttering with mine regardless on the spring type.
Old Nov 15, 2004 | 04:21 AM
  #48
TurbotrixRacing's Avatar
I love the greddy myself,, works perfect in the evo. IMHO ,, We had an MR at the shop the other day and it had the same bov as the 03's and 04's, i thought it was supposed to be metal, any insight on this ?
Mark
Turbotrix
Old Nov 15, 2004 | 05:07 AM
  #49
JustDSM's Avatar
Its possible that only the JDM MR's have the 'metal' BOV ???
Old Nov 15, 2004 | 07:05 AM
  #50
Huscroft6's Avatar
I thought I heard/read the same thing.
Mark, I have my appt for a full tune this Fri, would you suggest either the Turbo XS or MR BOV?? I have the XS but am anxious to try the MR. Any thoughts?? Thanks and see you guys Fri morning!!
Old Nov 15, 2004 | 07:12 AM
  #51
smp3000's Avatar
I think only the JDM MR's have the metal valve. Not the USDM models...
Old Nov 15, 2004 | 07:18 AM
  #52
jj_008's Avatar
All US models have the same plastic BOV.
Old Jan 11, 2005 | 02:01 PM
  #53
powerls's Avatar
Turbosmart Dual Port. The spring tension is fully adjustable by hand, no tools or shims are needed. It drops right it, no adapters are needed. It has a really nice rushig air sound, not the annoying whistle sound. 38mm inlet and outlet. Best thing is, it work. No codes, no lumpy idle, no stalling, no surging. It really is the best BOV I have found.
Old Jan 12, 2005 | 11:15 AM
  #54
evoleye's Avatar
Has anyone tried the the blowoff valves from ATP turbo?
Old Jan 12, 2005 | 04:08 PM
  #55
kimmievo's Avatar
I have the Works/GFB Stealth Bov...no bogging or stalling. Everything is pre-set to Works reccomendations, so you shouldn't have any problems after installation. And not to mention it sounds great. But, I agree, it is a little on the pricey side, about $320.00.
Old Jan 12, 2005 | 04:37 PM
  #56
bluevo's Avatar
Originally Posted by EVIL VIII
PLEASE TELL ME YOU ARE KIDDING?? The Forge recirculating valve is a piece of crap!! Took it out after two months and went back to stock. No lubricant on spring, if it gets stuck, blow-back will occur...unless that's something you want to have happen?!? If you are running anything more than 16psi (stock, don't kid yourself, stock is NOT 19 psi), then any OEM BOV will not work. GReddy is the only BOV that I have seen to hold more than 20psi...but I didn't look past that one. Do a serarch on Options Auto Salon, or any manufacturer's website for specs...
I agree with you, had the same problem with this bov (at 23psi) I'm now using Tial bov and it's just wonderful, at 25psi this thing is solid.
Old Jan 12, 2005 | 04:39 PM
  #57
TampaTurbo's Avatar
You may have had it installed backwards.
Old Jan 12, 2005 | 04:42 PM
  #58
TampaTurbo's Avatar
I recommend the forge recirc. Not just becasue I have one but based on experience to. Mark at TT made 420AWHP at 23psi. Solid boost.
Old Jan 12, 2005 | 04:54 PM
  #59
Evo8Master's Avatar
Aps B.O.V.
I would go with the aps dual vent!!! I have it and its awesome. Installs in 5mins. No adjusting needed, complete plug and play. Quality is top notch, holds all the boost. I never stalled or had any problems with this bov. I hope this helps. Good luck!!!
Old Jan 12, 2005 | 04:56 PM
  #60
smokey's Avatar
My .02 cents. Either a blitz.....although I have seen my friend personnaly destroy his blitz....couldn't hold the boost past 25psi. It ripped itself apart internally.
SOme people don't like it but I love it and that is the HKS SSQV. Just do a recirc on it and you shouldn't have any problems with stalling.....the downside for you is that it doesn't sound like stock......but it sounds awesome with 22psi going through it. It flutters when shifting at 3000 rpm, but when you step on it and shift at 5, 6 and 7000 rpms....it sounds mean.
Just my opinion
