Help reading plugs
Help reading plugs
Hey guys, if Mark or Junior could chime in I would appreciate it. I just pulled the stock plugs to check them. The ring is black while the electrode / post is white/dull white. Is this a sign the car is running lean or what? I have lots of pictures and can post them if need be. Your input is much appreciated.
I then put in BPR8ES plugs and am getting the same color. I have no wideband right now to confirm a/f.
Nothing has been done to the car since you installed the cams and reflashed it in Pensacola (Black EVO/272's).
Thanks!
Thanks!
Thanks!
Thanks!
Sounds perfect.. The dull white electrode will normally go down the the ring of the base. The shorter the burn spot ( dull white ) the colder the plug. Hope this helps. I'd be happy to see pictures, but i know what your describing and your fine
mark
turbotrix
Here's a link to a pic of the original plug.
http://mail.streetfire.net/PhotoDeta...5A89CD63CD&i=4
Car is running great. Thanks!
