CO High Altitude TT re-Flash
I was just wondering whether TT has any experience with EVO's for high alt. mail-in applications.
I live in Denver and plan on reflashing soon after I install my turboback exhaust. Also, I've heard that with TT flash you still must have a MBC of some kind is that true?
I hope to be running around 300-320 awhp up here. Do you think that's possible with:
-TB exhaust
-K&N drop-in filter
-Blitz DD BOV (w/hard spring)
-Hallman MBC set at 21 psi
-Walbro 255 lph
-TT reflash
Any info would be much appreciated, thanks...
-TB exhaust
-K&N drop-in filter
-Walbro 255 lph
-TT reflash
-TB exhaust
-K&N drop-in filter
-Walbro 255 lph
-TT reflash
-TB exhaust
-K&N drop-in filter
-Walbro 255 lph
-TT reflash
With that in mind, I guess setting the MBC at 19psi for mountain driving would only result in running rich, that doesn't really bother me; seeing as how I like to get up and ride every winter. Thanks for the replies though.
I'm pretty impressed as well with the S-AFC. I know you can do much more with an AEM/EMS but for now the S-AFC is doing just fine.
Here are my mods:
3" Helix turbo back w/ Helix hi-flow cat
PRO1 exhaust manifold
DnP O2 housing
HKS 272/272 cams
Buschur MAF pipe
Buschur UICP
Buschur FMIC
HKS SSQV BOV-VTA
8.5mm plug wires
255lph fuel pump
S-AFC
Profec B-Spec EBC
344AWHP / 350AWTRQ
The tune was very safe. Much more room to play with. I have a few more things to do then it's back on the dyno. Get your mods done!
Here are my mods:
DnP O2 housing
HKS 272/272 cams
Buschur MAF pipe
Buschur UICP
Buschur FMIC
HKS SSQV BOV-VTA
8.5mm plug wires
255lph fuel pump
S-AFC
Profec B-Spec EBC
344AWHP / 350AWTRQ
Originally Posted by stvbreal
Good question.
I'm at 344AWHP at 21psi on 91 octane w/ S-AFC and would be curious to see what a flash would do to help.
You don't live too far from me buddaboba.
I just did a mail in the other day for a guy with an afc, who tunes himself. Basically the afc is great but you lose low end power over a flash. So what i did was advanced his timing at peak torque and kept his timing figures stock up top. You will find on average about 30 more ft lbs with a flash over a safc, up top you dont see a big difference over safc only because the afc tricks the ecu into running more timing with the airflow signal interupted .. Hope i made this clear..
Mark
Turbotrix
Thanks for the info.
So with a flash I would basically have to disconnect the S-AFC.
I'd like to look into getting a flash if possible from you guys.
will you guys ever be coming to colorado and doing flashes i would also be interested in getting a flash from you and doing some fine tuning with a safc let me know thanks
evoisdream
evoisdream
evoisdream
evoisdream
Yes, it would actually be better, if you don't particularly want to tune everything yourself, to get a reflash. And, yes, this does render an AFC obsolete or silly. The problem is, many of us have the uncontrollable urge to tinker with our cars, so an AFC is absolutely necessary. I have been back and forth on whether or not to go with an AFC, total EMS, or just a reflash. My problem has always been how will I extract the power I want myself? The answer: probably can't. So I've decided to do a few mods and let TT or Dynoflash have their fun with my ECU. I would love it if TT came to COLORADO!!!!! Just my 2c...
BTW - We're having a drive this weekend in CO - https://www.evolutionm.net/forums/sh...d.php?t=114581
Evoisdream will be there too....
