272 or 280 ix cams?
Old Mar 27, 2006 | 09:00 AM
EVIL_EVO_VIII's Avatar
Originally Posted by S-1
do you happen to know what kind of numbers they put down?
one did 323whp and 335whtq@ spike to like 25 psi down to 22, this was on a mustang dyno. The other one did similar numbers that had more mods but the car was having misfiring problems
Old Mar 27, 2006 | 09:02 AM
rlazer5000's Avatar
Originally Posted by Reefer650
Im totally Confused, BUt I thought MIVEC Cams were totally different then regular cams. Do the new cams Still let MIVEC kick in or wat?
MIVEC is only controlled by the intake cam, where as the exhaust cam is still the same or similar to an 8's exhaust cam. People with IX's are only swapping the exhaust cam for a 272 or 280 cam.
Old Mar 27, 2006 | 09:15 AM
cdavy's Avatar
Registered User
Even if you used an one of the upgraded cams that are available on the intake side remember that MIVEC controls cam timing on the gear itself and not on the use of lobes like VTEC. So in this case there is really no "kick in." Basically like a dynamically adjustable cam gear on the intake side able to shift the power band on the fly...
Seems really effective, would be cool of it did both intake and exhaust! Who knows what's next!
Old Mar 28, 2006 | 08:03 AM
j3ffw19's Avatar
just ordered tt 280 intake cam should be here in two days. thanks mike
Old Jun 13, 2006 | 09:59 AM
dsmjeffro's Avatar
evo ix 280 cam
i installed an hks 280 exhaust cam in my car i cant even tell its in there
i didnt notice and change in exhaust not while at idle
......be sure to bleed those lifters the start up is scary very noisy...........
